- May 18, 1997
The new motherboard from Gigabyte designed for Threadripper 2990WX overclocking.
50 amp MOSFETs....
50 amp MOSFETs....
Yes.Aquantia NIC?
Asus proabably was over built. The new chipset proabably doesn't even bring much.Interesting that ASUS decided to just offer VRM fans and MSI and Gigabyte decided to bring out new boards. Both this and the MSI Creation look really beefy.
128GB of RAM... My wallet...
My wallet...
also $500 price tag for this monster.
So you are at 2300 list for CPU/MOtherboard alone.
That is a very nice looking board. Awesome to have the 10gb onboard as well as 2 other nic ports.
It does open up the possibilities a bit*- but what would really open them up would be official** ECC support. I wouldn't even mind if they did a 'soft segmentation' and charged a bit more for 'workstation' versions with ECC support, not dissimilar to what Intel does with their consumer-socket Xeons.
*[two gigabit NICs plus 10Gbit allow for a full-stack network segmentation (i.e., physical layer/layer 1 up to application layer, by default), such as running inline network filtering on a WAN or other link, while also allowing for high-speed network access for the rest of the system say for accessing NAS/SAN resources, or for providing them]
**[and I do mean official, not 'the hardware is there and it's not not supported' like we see with Ryzen (non-Pro) on a few consumer boards- [main use for ECC in a workstation environment is for soft RAID arrays; whether running a ZFS-supporting OS on the hardware or passing drives through to a VM, ECC goes from being 'recommended' for basic network fileserving to 'almost required' for workstation-level storage usage]
I’ll be keeping an eye out for ecc support, definitely would feel better with it but it’s as much for the bigger dimms for me,
but now this post makes me wonder if I should consider paying more and get ECC since this will be for work.
I wonder if this board solves the issue where it was a pain in the ass just to secure the screw with the CPU installed inside the socket, it was so annoying and time consuming just to get the screw secured, apparently it was an issue with most if not all TR4 boards because of the socket.
I assume you want to go with 4 sticks of RAM for this? It pains me that 16gb modules are less per GB than 8gb I don't really need or want to spend the money on 64gb to start when 32gb will be fine.
Looking very interesting!
I am excited to see what Asus ROG will do with an X399 Mk2 (I don't suppose AMD's iterating to X499 the way they did with X370 > X470, but if they don't have an improvement to the chipset its good they're not just doing so for hell of it and instead giving owners more support for their existing boards) board. However, from a comment above it suggests Asus is not planning on launching a new board to go alongside the Threadripper 2000 series? Maybe its not really necessary I suppose, but given the potential for OCing CPUs with double the max cores and simply that X399 was a first iteration etc... I thought that they'd want to build something new with all they learned from the last model. Then again, maybe the Asus ROG Zenith Extreme already was a cut above and other boards are just now catching up (ie I can remember Zenith had 10-gig ethernet card using the same chipset as this Gigabyte ete). Still, I wonder how they will all stack up...
