Gigabyte P35-DS4 Drivers
Superfly3176
I can't find working LAN Drivers for Windows XP 32-bit anywhere. Can someone help i lost my disc.
Just go to Gigabyte's website and download the LAN drivers from there onto whatever PC you're using to post on the forums right now.
Did that they don't work though. They go like half to 3/4's way through the install then the program exits and never finishes.
Are you sure you got the right drivers for the right motherboard revision? There are 4 different revisions of the GA-P35-DS4. Make sure that you're downloading drivers for your motherboard revision.
