Gigabyte P35-DS3L DVD ROM issues...
HybReD1234
Well after a bit of work to get the thing up and running because of the route I went with the hard drives... It was a pain in the ass because I couldn't use my own optical drives to boot up XP on and I had to use my old PC back and forth etc. Anyway, I thought it was just a funky issue with the HD and what not. Guess not.
I figured my TWO Drives were just DOA. I bought a Samsung DVD/ROM and a ASUS Lightscribe for this new rig. The ASUS doesn't open and just has a constant light when I have it plugged in. And sometimes I can't even boot with it plugged into via SATA. So atm it's not even plugged in. My Samsung works like it should except for it isn't spinning to read the disks. So I just figured they were both DOA. But then I pulled out my old IDE Drive that I know works and it doesn't spin either when it's hooked up. All 3 are detected on the computer, but none of them work on this motherboard.
Is there something I can download to fix this or did I just get a fubared board? I downloaded all the latest drivers from the Gigabyte website. The only thing I HAVENT done is flash the bios.
Sigh... Runs great though... I just wish I could bust out Crysis... :(
More than likely you do not have the SATA configured properly in the bios, certain ports do certain kinds of emulation, read the manual carefully. Look at the bios and see what options are there and which ports are put into what modes based on the bios selection, make sure you plug the optical ones in the ports that are configured for optical.
Everything is right in the BIOS... There's only two options to mess with AHCI and SATA Port0-1 Native Mode. Neither apply to this situation... And according to the BIOS anything can be plugged into the SATA.
/Sigh..
