I have 3 120MM 3-pin fans on my Gigabyte board. My other two fans are attached directly to the PSU.
They are all EverCool 120MM clear fans. Pretty silent.
I have my Bios set to SMARTfan disabled. Is this the right setting in my situation? Is it normal for such fans to then spin about 1250-1400 RPM? I thought with smartfan off fans would go at max speed. Are some 120MM fans 1400 RPM at max?
In any event my case is a P180 and is still quiet with all these fans. And my temps seem good. So I probably don't need speedfan, but just so I know, with all 3-pin fans is any kind of automatic fan control possible?
