Gigabyte Motherboard Help
DeaconFrost
I'm about to set up my new system using a Gigabyte GA-EP45-UD3L motherboard. I'm fine for drivers, as I've built hundreds of computers and done many many more OS installs. However, believe it or not, this is my first Gigabyte board. Let's say I'm not going to be overclocking right away, what Gigabyte apps should I install for a Windows 7 x64 system? I'm used to Intel boards which don't usually have apps to go with them, and the BIOS upgrades are done by a downloadable Windows app.
So, for those of you with similar boards, what apps do you have installed from Gigabyte?
I'd like to know this for sure too, lol. I remember seeing a post (or a few) where none of the included software was used, but I don't remember anything about it specifically.
I have the provide Azalia Gigabyte Sound patch for Realtek users installed, also the Etuner or whatever its called, and Easy Energy Saver, and there BIOS flash tool.
Concerning motherboard apps, i never installed any as most are crap. Coretemp/realtemp, cpu-z, speedfan is about all i used to monitor temps etc.
Windows 7 includes lots of new drivers including mobo, usb, etc so once you've installed OS, check out your 'device drivers' page for any missing ones and then install them.
