rodsfree said:Well,
At the current state of mobo/cpu development - the mobo/cpu is the reason that we can't just throw more RAM at our systems. Fix them then we'll be able to pass the 4GB barrier on our PCs.
That plus cost of the components.
Cheaper than what? The memory cost is about the same or slightly cheaper per stick; the i-RAM itself costs as much as a half-decent desktop motherboard.
Maybe you missed this:
mikeblas said:I think it's been said before in this thread, but I'll say it again: there's nothing wrong with peripherals like the i-RAM if they're applied sensibly. But they're not cure-alls, and I don't think they make much sense for general-purpose computing until you've maxed-out the physical memory you can put into your system.
IOW, the point isn't building a machine that has 16 gigs of memory. The point is maxing-out the memory on the machine you already have. If you want to build an i-RAM-based machine to play with booting Windows from a RAM drive, that's great; be my guest, and I hope you have fun with it and report your results here.
On the other hand, if you're expecting general-purpose performance improvements by installing one in a system that doesn't have the maximum amount of physical memory already installed, I think you're approaching the problem the wrong way.
