I don't think it will be different thant XP in that respect.seto said:I expect Vista to be able to address and use 4G of physical system ram.
xX_Jack_Carver_Xx said:The only way I'd use the board is if it was NOT PCI based, but ran off a molex power connector, had 2 SATAII outputs so it could act, if desired, as a raid array... 0,1,etc, and had 8 DIMM slots for ddr.
Would make a great place to retire old DDR to.
Could be placed anywhere inside the case
if it is so bad, why then has nobody else produced a better device?The possibilities are numeorus, the lack of vision for features by Giga is pathertic.
*racism alert-you've been warned* This is what you get when relying on 3rd worlders to innovate.... they DONT 99.9% of the time. And as outsourcing places more of the responsibility for innovation into 3rd world hands, less and less of it will occur.
seto said:so where do you plan on getting the power from? other than wake on device hacking?
benamaster said:I don't see why they can't find a different kind of battery that would last longer. Secondly I also agree there is no reason to waste a PCI slot just for power.
drizzt81 said:I totally understand you. I mean, we could just put a lead-acid battery right next to my case and that surely would keep the iRAM powered for a week or two, not a problem.
Come on: Half the people in this thread are complaining about the iRAM's price and now you want to increase it significantly by finding a >1700mAh battery and slapping it on there?
Also, if you read the articles in the PSU forum about ATX power connector adapters, you will see that they are a bad idea. For that reason the 'hack' that Gigabyte has done is actually very elegant, since it does not require any modification apart from plugging the card in.
mjz_5 said:True.. All they need as a PCI card for power that goes to a 5 1/4" bay that has 8 ram slots a 2 SATAII 300 for RAID 0 performance
Ockie said:Also, you dont need two sata ports for raid0 performance, rather just get two units and raid them... more storage that ways.
Ockie said:They are coming out with a baymount version that doesn't use pci for power, the second they do, I'm down for two of them.
Cause molex doesnt supply power when the computer is off?Ockie said:Why not just use a molex connector
The PCI card doesn't have to be full-height. It could be just a tiny thing that goes into the slot (and doesn't even have a metal bracket on the back, so it might work with dual-slot video cards) and supplies power. There's no other practical way to power this thing, unless you're going to have an external power brick and all that entails. I'll stick with PCI slot power, thanks. A huge heavy battery isn't my idea of a good time, either.Ockie said:Why not just use a molex connector and leave the pci slots out of the picture all together? I mean using a PCI slot is bad, for starters, I dont have one left, second of all is that most people running SLI does not want a card sandwiching their video cards...
Jason711 said:eSATA would be pretty cool. could have its own seperate psu with battery backup.
for $99 I'd buy at least one.unhappy_mage said:
Sure, but my point isn't that it's a good idea, it's that it's impractical or someone'd be doing it. The demand isn't high enough for these things to drive the prices down. I mean, even with 8 sticks of the cheapest 1GB sticks on newegg (at just under $500 for the lot) you've spent $600 for an 8GB drive. Granted, it's hella fast, but there just isn't enough demand to make bulk manufacturing practical. And if you keep demanding new features (which won't help much - if the current iRam is as fast as it looks, why do you need double the STR?) you keep forcing them to abandon the old ones and move to a whole new board. That's not helping things any.drizzt81 said:for $99 I'd buy at least one.
unhappy_mage said:Sure, but my point isn't that it's a good idea, it's that it's impractical or someone'd be doing it. The demand isn't high enough for these things to drive the prices down. I mean, even with 8 sticks of the cheapest 1GB sticks on newegg (at just under $500 for the lot) you've spent $600 for an 8GB drive. Granted, it's hella fast, but there just isn't enough demand to make bulk manufacturing practical. And if you keep demanding new features (which won't help much - if the current iRam is as fast as it looks, why do you need double the STR?) you keep forcing them to abandon the old ones and move to a whole new board. That's not helping things any.
And if, say, they can't get enough people to get the cost below say $110 (so they make a profit - this is a business, not a charity!), they'll have to raise the price to, say, $150. And some few people will drop out - they signed up for $125, they're on a tight budget, $150 is too much... and they have to raise the price again. I'd imagine it's really hard to talk anyone into committing for $125 a pop when the circuit board hasn't even been laid out yet.mjz_5 said:they should take orders for them @ 125 dollars. See how many people order, than adjust price if necessary. with a disclaimer though
soekev said:Where can you actually buy the iRAM 1 now?
yes and here is a reason why people shouldn't add connectors between their ATX PSU and their mobo:Ockie said:They do not need a pci slot nor do they need an external power brick.. you can tap directly into the 20/24pin ATX cable by using the live wires. So all they need to do is make a interceptor cable that plugs in between your board and psu and then has a wire running to the bay mount.
mjz_5 said:i wanted to get a iRam, however, i wont be able to use it.. My ATI x1800XT, sound card and tv tuner are taking all my PCI slots
iansilv said:all the PCI slot does is give power when the system is off to keep the data intact. Which part fo the pci slot sends power? Why can't someone engineer a ribon connector that comes off of a riser that allows you to mount the iram somewhere else in your system but still draw poer from the pci bus to keep the data in tact? In theory, depending on the amount of power this thing uses, youcould stripe multiple irams and have a 8, 12, or 16 gig drive without using pci slots- if the ribon running the power supply comes off of a riser.
Thoughts anyone?
unhappy_mage said:
Ockie said:Yes, however you can only have as many as you have pci slots and your limited by size and physical spacing... whereas with iram2 you can have as many drive units as you have sataports and bays.
mjz_5 said:an anandtech review says that gigabyte doesn't recommand RAIDing the iRam.
