TheKitsuneWithATie
- Jul 15, 2017
Hi, I currently have a few spare parts laying around and I'd like to build a gaming HTPC.
The case I want to use is an Antec NSK-1380, its power supply comes in a non-standard form factor, it's rated for 350 watts, is 80+ certified (white) and doesn't have any PCI-E connectors. As the power supply doesn't comply with any form factor standards, I have to keep it if I want to use this case.
From the informations I gathered, the GTX 750 Ti is the most powerful graphics card I could use with this power supply.
I have a chance at getting an used Gigabyte GV-N75TOC-2GI (overclocked GTX 750 Ti). It apparently doesn't require any auxiliary PCI-E power connector and doesn't seem to consume much power, but Gigabyte's website indicates that it requires a 400 watts power supply minimum.
Here is the other components I have for this build:
Would the Antec NSK-1380's 350 watts power supply handle the Gigabyte GV-N75TOC-2GI and the rest of system without any risks? If not, what is the best graphics card that I could get working on this power supply?
Thank you in advance!
P.S: I didn't knew if I had to post this in th Video cards or Power Supplies section, but as I ask for graphics card recommendation, I posted it here. Please excuse me if i made a mistake.
- CPU: Athlon X2 250 or Phenom II 955 Black edition
- RAM: 2x DIMMs of 4Gb DDR3 @ 1600MHz
- Drives: 1x SATA III SSD or 1x 7200RPM hard drive and 1x Optical CD/DVD (maybe Bluray) drive
- Wifi: 1x PCI 54mbp/s Wifi card
