Gigabyte GA-P35-S3G
StrikeX2
is teh metal CPU clamp suppose to be bent?
i got a DOA motherboard last time and it was bent so i send it back to newegg and they shipped another one and this one is also bent.
is it suppose to be likt his?
Yes, I believe they are supposed to be slightly bent to give a bit of clamping force in the middle. The bend in your pic looks like it is more than I am familiar with but if its the second one with the same angle of 'bend' in it, I'd say that's the manufacturing norm now.
Its fine, the picture makes it look bent at a higher angle due to the flash reflection..
it looks more bent than normal to me personally, but it could just be the flash.
It's pretty clear where the flash reflection ends and a larger physical bend starts, but whatever, isn't my system.
