gigabyte ga ex58 ud3r
Discussion in 'Motherboards' started by Rbix, Oct 13, 2016.
  1. Rbix
    Rbix n00bie
    1
    Oct 13, 2016
    Hi all,
    I got the gigabyte ga-ex58-ud3r.
    I've been told it has super high electricity consumption. Does it true?
  2. cyclone3d
    cyclone3d [H]ardForum Junkie
    12,158
    Aug 16, 2004
    Yes, it will cost you approximately 3,000 German Marks per day to run.
    Luckily, I have a huge stash of them. To save you the hassle and money, you can send it to me.
  3. i7Baby
    i7Baby Limp Gawd
    170
    Aug 31, 2016
    Bit Cruel.
    The motherboard itself won't use much power - like 10W. But the graphics card and the CPU you plug into it will.
  4. Dr Tuek
    Dr Tuek Gawd
    522
    Oct 20, 2016
  5. Starbomba
    Starbomba Limp Gawd
    254
    Aug 24, 2014
    All motherboards do not use that much power. X58 boards in general used a bit more to drive the IOH (those 36 PCI-E lanes aren't free) but shouldn't be over 30w.
    In the other hand, most X58 CPUs are rated for 130w, even more when OCed. Add to that a good GPU, and you can easily use up a 750w PSU.
  6. Mr. Stryker
    Mr. Stryker [H]ardness Supreme
    5,210
    Mar 15, 2005
    I've had one of those before with a i7 920 & 980X EE, I noticed that you would need a quality 650W PSU at a minimum if you're going to be using it full-time with a good graphics card. Although, it died on me when I used the EE chip after 3 months. So I probably had bad luck. Either way, it should be fine if you kept it cool, because the NB and MOFSET heatsinks got really hot often.
  7. rgMekanic
    rgMekanic [H]ard|News Staff Member
    4,816
    May 13, 2013
    truth there, the IOH on X58 gets blistering hot, especially if you have the CPU under water
  8. Napoleon
    Napoleon Gawd
    979
    Jan 27, 2003
