GIGABYTE GA-EG41MF-S2H
King of Heroes
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128367
Came across this while browsing Newegg. Looks like a revision of the GA-E41M-S2H, but the HUGE difference between the two is that this one has a full x16 physical/x16 electrical PCI-E slot. Which is a noticeable improvement over the x16/x4 electrical slot of the original. I confirmed this on Gigabyte's product page:
http://www.gigabyte.com.tw/Products...oard&ProductID=2954&ProductName=GA-EG41MF-S2H
Expansion Slots
1. 1 x PCI Express x16 slot, running at x 16 (Note 4)
2. 1 x PCI Express x1 slot
3. 2 x PCI slots
(Note 4) The PCI Express x16 slot share the PCI Express x16 bus with the HDMI and the DVI-D ports. When the PCI Express x16 slot is in use, the HDMI and the DVI-D ports become unavailable.
I can't confirm whether its PCI-E 2.0 or 1.0/1.1. Since its a 4 Series northbridge, I assume its 2.0?
On top of that it has onboard Firewire and Gigabit Ethernet. The only drawbacks are the, I assume to be, dated ICH7 southbridge and only 1 PCI-E x1 port. I really wish they'd ditch the 1xPCI-E x16, 1xPCI-E x1, and 2xPCI configuration already for mATX. At least scrap one of the PCI slots (the one farthest from the x16 slot) and replace it with a second PCI-E x1.
For someone considering moving over to mATX, this looks like a good option to consider. Has anyone used this board yet?
It looks like it's their new 'cheapie' board, probably bound to replace the G31. Funny how they put PCIe x16 on this one and yet their G43, G45 are only PCIe x4. You gotta wonder.
The problem is that it's too expensive compared to the old G31 board. I picked up one of those for $50-55 a few months back. There are plenty of Nvidia based boards that run in the $50-60 range that are probably equal to the video on the G41 and have RAID thrown in also.
I'm looking for a good deal on a cheap mATX board to OC a E5200, but haven't come settled on one yet :(.
Really needs to be like $20 cheaper at the very least. Other then that it looks pretty decent but stupidly priced.
No-one got one then? I was Googling looking for reviews or OC experience on this board.
It's 5 months later from the OP and it's still expensive. That board is way overpriced for the features.
Newegg reviews aren't too encouraging either re OC. The G31M-ES2L is still the king of the cheap mobos, me thinks.
