I just finished a new build (btw, thanks to all of you for helping me select parts)...maybe someone could help me out with this issue...
I got everything up and running ( using the DS3R mobo, 4 gigs Corsair XMS2 ddr2 800 memory, put in the HD and vid card and DVD burner ) and I WAS getting the single short beep from the PC Speaker (provided with mobo), which indicates a successful boot...all fans spin, etc...
Installed Vista Ultimate 64-bit successfully...Now, when I boot up, everything still works fine, and Windows loads, and everything appears to be in working order, but I don't hear the beep anymore...
Like I said, everything still appears to be working, but is it possible that the "beep" was somehow deactivated? Would the Vista install somehow do that?
Anyone know if there's an option in the DS3R BIOS to disable the diagnostic beep? I don't see it in the manual or by searching through the BIOS itself...
I did tidy up some wires after the OS install, but I checked the PC speaker and it seems to still be correctly attached to the 4 pins on the mobo...
I have to get this box out to the dude I built it for, and I'd like the diagnostic beep to be there when I do...and yes, I am relatively new to building systems for people other than myself...
thanks guys...any help is appreciated..
