I just built my new rig and for some reason it is not recognizing USB devices. I got it working initially but once I installed the drivers from the Mobo software disc the USB mouse and keyboard stopped working. Anybody know how I can fix this?
Also, I see a number of BIOs updates on the Gigabyte website: http://www.gigabyte-usa.com/Support/Motherboard/BIOS_Model.aspx?ProductID=2583.
Each version seems to correct something different so does this mean newer versions correct all issues listed in past versions or each BIOs update fixes something diffrent so I would have to update with every BIOs update. Please help. Thanks.
