Gigabyte DS3 and eSATA
M4tt said:
IcyDock
http://www.newegg.com/Product/Product.asp?Item=N82E16817198003
Expensive but very nice build quality. Left a Seagate 7200.10 in it for days and barely feel any heat using the retractable feet.
They also have cool enclosures for multiple drive bays. The housing for the hard drives may even be interchangeable but not sure.
Nice enclosure but cost twice as much as the one I posted. What made this one cost so much more? does it have an auto-on-off feature?
The DS3 doesn't have a port for eSATA on the back of the mobo.
I knew that the DS3 dosn't have eSATA. The external enclosure I posted has a SATA-to-eSATA converter. I want to confirm that this converter will work.
I see no reason why it wouldn't as long as the SATA controller supports hotswapping drives (most of them do).
I use it on a daily basis and wanted one that was professional looking and solid. Notice no rainbow colored LED's or spotty manufacturer homepage.
I plan on keeping this enclosure for quite a while and it comes down to personal taste and you usually get what you pay for.
No auto-on or off.
After looking at both of them, I would be happy with either. None of the features of either stands out over the other. I guess it comes down to whatever one you think looks nicer.
