Gigabyte 965P-DS3P and Matrix RAID
xenithon
Hi all. I am going to setup a new system in the next couple of weeks. Now that I am moving from AMD to Intel and have the option of Matrix RAID, I will use it to setup a matrix RAID on two drives of mine. Can anyone let me know what order things should be done in, in particular with regards to setting up the RAID and then installing XP?
Normally I use nLite to slipstream SATA drivers and install straight, but this time around I assume RAID will be setup before the install, so questions are:
- do I need any drivers or floppy disk to setup the RAID?
- should I setup the RAID 1 (OS -> the safer one) drive first or the RAID 0 (the quicker one for general files) first? I read somewhere that one should be setup first so that it is first on the platters of the HDDs, but cannot recall which :(
- will I still need the use F6 and a floppy (or slipstream drivers) for XP to recognize the matrix RAID drives? If so, would I use the regular ICH8R SATA drivers or a different one for the RAID setup?
Thanks and Regards,
X
questions are:
Well I can tell you what I did on my DQ6 and it should be the same. Including a lot of detail you dont need probally, but just in case someone else not as knowledgeable reads this.
Yes the board will come with driver floppies for both the intel and jmicron/Gigabyte raid that should be installed during OS install (F6). I would check Gigabyte site for for the latest and make sure you get the correct ones for your operating system. Go ahead and bookmark the product page for you board ;) Here is the verion 3.3 linky, check and make sure of your board version.
http://www.gigabyte.com.tw/Support/...board&ProductID=2455&ProductName=GA-965P-DS3P
You will see Gigabyte labels them pretty well in that the title has "F6 Preinstall" in it. Also get the latest "normal" windows drivers for the intel and jmicron as well. I recommend you F6 install both the Gigabyte and Intel drivers during OS install even if you dont plan on using the Gigabyte/jmicron one in raid mode. If set in IDE/RAID mode the Gigabyte/jmicron one runs my DVD/CD drives fine.
(you could get these from intel as well but I use Gigabytes in hopes they are versions tested with their boards and atm they are in-step with Intel anyway. )
Might as well download the latest bios while you are at it but your board will probally come with latest, use the bios update utilty built into the bios main page, just have bios file on floppy, power on into bios, and hit a key,
OK, when you first boot the machine, go into the bios and set the mode for both the intel and Gigabyte controllers to IDE/RAID or whatever it says that is NOT ACHI, cant remember at the moment exactly what is says :( . Set memory voltages etc. as needed but best to leave most a defaults until you get all the software installed. Find the boot menu and set it to boot from CD first HD next then floppy.
Ctrl + F1 from the main bios screen will enable the voltage controls in the MIT sub menu. Setting are + some voltage from the default so for memory its added to 1.8 V so for example to get a Vdimm of 1.9 volts set the memory voltage to .1
Set the memory speed/divider to 2:1 (this is the standard setting for running memory at 2 x the FSB for DDR) you can leave it on auto but it can do weird things once you get around to overclocking, set it now and forget it, note that on a failed boot and cmos reset you will have to come back and reset it.
Now with the preinstall driver floppies ready and the OS cd in the drive reboot and press Ctrl + i to get in the Intel raid setup, you will be prompted during boot, and assign your drives to the array and the array type. Its dead simple if you have made note of which drive is connected to which port on the board.
Be ready to hit F6 , its comes up fast and does not last long :mad:
You need to tell it you got another one after you first tell it "yes I have a driver" not sure exactly the wording and sequence here, but just carefully read the prompts, i managed to figure it out and most people are brighter than I am :D
Feed it the preinstall raid driver floppies, I seem to remember during the prompt for the Gigabyte/jmicron I had some question as to exactly what jmicron chip/dirver was the correct one, its the first one at the top of the list.
After that its normal install of OS, reboot, update windows, reboot, install motherboard drivers, reboot, install video drivers, reboot, install any other drivers, reboot.
NOTE: install this driver BEFORE you install the audio driver, I think the factory cd will do but but it would not hurt to do it manually after loading the OS but before installing Lan and audio drivers either downloaded or from factory CD. Latest on Gigabytes site. If installing Vista see if there is another version, might not be needed for Vista.
Microsoft UAA (Universal Audio Architecture) Bus driver (Full Multi-language version )
O.S. : Windows 2000,Windows XP,Windows Sever 2003
got to intel.com download section and get latest Intel Matrix Storage Manager and install if its a newer version than what came on the factory CD.
All this sounds more complicated than it is, if you have a second machine up and on the net during install its a breeze.
I was about to tell you "DS3 doesn't have the ICH8R"... but then I noticed you were talking about the DS3P
LOL yea that threw me too till I looked it up. Wish that had been out at the start, could have saved some bucks.
Hi there and thanks for the great post. A few questions I had though:
1. I got both the pre-install and the regular SATA/RAID drivers. Would I use that pre-install driver to make the F6 floppy regardless of whether it was regular SATA or RAID? or would there be different ones?
2. if the JMicron will be set to IDE only, I assume I do not need F6 drivers, correct?
3. if you have used nLite before, do know if I can just take the files that the pre-install program puts on the floppy and tell nLite to integrate those for an unattended install?
4. any reason you suggest the Microsoft audio driver instead of the official Realtek one? I see both are available on the Gigabyte site.
5. final question: do you think the Matrix RAID is worth the extra effort. The reason I ask is that in my system, I will have 3 drives. If I do not RAID I will have it like I do in my current system:
- one drive only for Windows, Program Files, and Settings
- second drive stores all my working info and miscellaneous files
- third drive (can either be internal or in an eSATA enclosure) is a backup, storing my important files and images of the OS drive.
In other words, considering the above setup, will Matrix RAID give any real-world benefits?
Cheers,
X
1) you only need the preinstall raid drivers if you want raid functionality. In other words if you where going to just use the disks as plain ole drives you dont need the preintall drivers at all. Nor would you need the "windows raid driver" installed after the OS is installed . They work together once its all in. If no raid, no drivers needed. However its a big pain to get the preinstall drivers in once the OS is installed. If you even think you might want them down the road, at least put in the F6 preinstall drivers now. wont hurt anything.
2) correct, but I recommend you install it anyway as its a pain to go back and do it. Also if you set it to Non-raid in the bios it will ignore the raid functionality and work fine with plain disks and devices on the ide cable. Your call but I took the "its there if I ever want it route".
3) dont know
4) The microsoft thing corrects an issue with the buss, its not really the driver, its more of a hotfix, then install the "actual" audio driver too.
i.e. install both, the ms one first.
5) probally not a lot, so maybe just install the OS preinstall drivers, again, they would be there if you ever wanted to play and you dont have to enable raid in the bios or the OS until you want too.
so in summary, I highly suggest you download the F^ preinstall drivers to floppy and hit F6 when prompted and put em in, takes 5 min of time do download, and 30 sec of time during win install. Assuming you have a floppy drive.
