Gigabyte 965p DS3 versions
Kassem
There is regular and there is rev 1.3
There is a nice price difference on newegg.
I sort of know the difference, however I was wondering how I would know if one of these was rev 1.3 or not when trying to buy one on ebay. Seems as though the sellers never list that.
There are three versions.
1.0, 1.3 and 3.3 I have a 1.0 and a 3.3 and to tell you the truth, besides an extra fan header, there is no visible difference. The 3.3 is 1333FSB capable where the other two are not.
If you ebay, just email the guy and ask what version it is. If 1333FSB is not important then it really doesnt matter.......some people have had "issues" with the 1.3 and 3.3 versions, but I found these boards to be stable as a rock even at very high overclocks.
The only major difference is the 1333fsb support, which is going to be the penryn CPUs later this year in Q4. Probably best to grab a 3.3 if you can get your hands on it to suport the next line of CPUs. There were also supposedly more compatibility issues with 1.3 and 2.0 versions of the DS3.
And yea it overclocks like a mofo. Right now I've got mine running at 515x7 fsb, making that NB chipset running at a 640mhz OC. Just downright nasty heh. Oh and definatly toss a fan on that northbridge you're overclocking it as well when you OC that fsb, and those passive heatsinks suck. :eek:
quote
"The major differences between various revisions are:
Rev. 1.0: FSB 1066MHz, one system fan header, ALC883 (Vista Basic Logo)
Rev. 1.3: FSB 1333MHz, one system fan header, ALC883
Rev. 2.0: FSB 1066MHz, three system fan headers, ALC888 (Vista Premium Logo)
Rev. 3.3: FSB 1333MHz, three system fan headers, ALC888"
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2030955&enterthread=y
This is correct. Not sure if the 1.3/3.3 are going to support 45nm. I don't expect them to, but 65nm 1333mhz bus CPU's should work fine.
