Gigabyte 965p ds3 question
It constantly astounds me that what ? People do not think Gigabyte does not have a web site ? We are your "I am too lazy to look it up " monkeys ? Well guess I am. :D
The 1.3 is the older version, the higher priced one should be current latest version 3.3 and if I bought it and it was not, I would return it (since they are charging more). The newer one has formal support for the new 1333MHz FSB Intel CPU's . Looks like the sound chip and Ethernet chip is changed on the newer version, probally more due to time passing and what is commonly available more than they are significantly better than the old ones (if you are a gamer over the net, $30 3Com NIC card is the way to go anyway) .
http://www.gigabyte.com.tw/Products...ComparisonSheet.aspx?ProductID=2456,2424,2314
eek eek eek (scampers off to find a banana and a cup of coffee so I wont be as surly to the next poster, Sorry. ).
To further make amends have a look at this regardless of which one you buy. Should get you started quickly with the bios settings. Before you put it a case, run it overnight to make sure its ok, then re-do the heatsink compound on the northbridge/MCH and put a fan on it.
http://www.hardforum.com/showthread.php?p=1030795318
Thank you.. yeah gigabyte's website says nothing about overclocking. That was the info I really needed, not just the basic differences. I should have rephrased my question.
Price difference between the 2 versions is up to 30 bucks. Worth it for a better overclock? That openbox one looks abnormally cheap.
I'm almost certain the open box is not a rev3.3 board, lol.
What CPU are you planning on getting? I would seriously consider the P35 boards instead, like the P35-DS3L or P35-DS3R. The Abit IP35-E from mwave is also nice
