Gigabyte 8SG667 replacement
BigJavy
Lurker
Hey,
I've got a Gigabyte 8SG667 that's gone bad so I'm going to try to replace it. Unfortunately, 8SG667's aren't easy to come by any more so I've got to find something else that will work. Is it best to go with something similar, or will it not make a difference?
If it's best to go with something similar, than the closest thing I can find (though, I've only really checked Newegg so far since it lets you search by chipset) is this: http://www.newegg.com/Product/Product.asp?Item=N82E16813135217 . Anyone else have any suggestions. It doesn't have to be anything especially great. Just something stable with maybe a little overclocking potential, but if not - no big deal. Oh, here are the specs for the 8SG667: http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1397
Is there anything else I should keep in mind if I'm going to do this? Thanks for the help!!!
Jason
I'd just get an Intel 865/875 chipset board and call it a day. Might have to repair install, but you'd be better off. Even an 845 chipset board would work.
