Gigabyte 650SLI DS4
kirbster
I just picked one of these up with an e4300 to play with. Anyone here have any time on one of these?
So far i am finding it a bit odd compared to my X2 3800 setup. But it is very fast. Even at 2.5 it is anywhere from 10-25% faster in any benchmarks i have run compared to my 3800 at 2.7.
The bios seems to act up every so often and i am having trouble getting a consistant overclock. There seem to be FSB holes that appear. I am trying to figure that out.
At one point i had it stable at 3.3GHZ and was running memtest 86+ without issues but for soem reason i cannot get it to do it again and there are times it just wont enter windows at all.
Still figuring it out, would like to hit 3ghz or so stable. I am using a Scythe Ninja Rev.B.
Long long time since i used Intel. Got some lurnin' to do!
Yes, there are FSB holes present in these boards. I'd see if you could shoot for something that's a nice round number like 300/333/366/400 and then just adjust accordingly. 333x9 = 3Ghz. Can you boot at that speed? I haven't tested it much, but I would imagine it has something to do with the northbridge straps.
suddenly there are kirbys everywhere.....;)
We even have the same board!
Anyway...yeah i did get it to boot at 3.3 (366 x9) at one point and even ran a few passes of memtest at that speed, but it is a bit quirky with settings and i find what works once may not work again.
I have even had options disappear out of the bios menu. (one of the speedstep settings).
(i do know about the ctrl+F1).
The one time i got it to work i lowered the multi to 6 and went 6x366 then bumped to 7 then 8 then 9. I gave it 1.45V and it was stable using UBCD prime test but since then i have not been able to enter windows at anything above 280x9.
I am still working on it though.
running unlinked with memory set at 800.
What have you been abe to get out of yours?
I don't have one of those fancy SLI boards :p. I'm using a P5W 975X board with a E6600. I run 24/7 at 367x9. I just turned Speedstep on to see how that works. It runs 2.2Ghz when that's running (still plenty fast).
I did just pick up an E4300 with an Abit IB9 board (both were $185-190). I'm shooting for 3.0Ghz so I'll probably set it to 333x9 and see if it'll take right off the bat. I just installed Windows on the machine, so maybe later today or later this week I'll start OCing it. I need to get a different bios for it also :(.
I just purchased all my parts for my new system and the DS4 is the mobo I went with. Unfortunately I'm still waiting for my powersupply so I won't get a chance to build this until this weekend.
Check out the review here http://www.vr-zone.com/?i=4939&s=1 they mention these gaps and a few other quirks.
so far i only have 100% stability at 266x9. all stock volts.
Using the Gigabyte software to monitor temperatures i get 21C at idle, but as soon as i load up both cores with orthos or prime 95 it goes up to a bit over 50C. That seems like a pretty big change. Using coretemp i get 63-70C under full load.
The heatsink is seated well as far as i can tell, (Ninja Rev.B). I may try the stock one for comparison.
Something just doesnt seem right. I am using an OCZ powerstream 520 which should handle this setup no problem at all.
Any suggestions?
ok, I remounted my ninja after lapping it a bit, temps are down by 5C. I can now run stable with dfault core voltage at 3Ghz. I may take another shot at lapping it some more but 3Ghz was my goal for teh time being so thats where its going to run for a while.
Thsi board/chip combo is definitely a bit quirky though. Many holes in the FSB settings.
