HardOCP News
[H] News
- Dec 31, 1969
The folks at Penn State have developed a wireless technology that uses light waves. What makes this different is that no direct line of sight is needed to transmit data. As long as you don’t have walls painted flat black, the data will literally bounce off the walls and be picked up by a receiver.
Sending information via light waves either in physical light guides or wirelessly is not new, but existing wireless systems either require direct line of sight or are diffused and have low signal strength. The researchers chose to take a different approach using multi-element transmitters and multi-branch optical receivers in a quasi-diffuse configuration.
