Gigabit Problems
Karant
Ok, when I first got my ASUS P4P800 SE motherboard with Gigabit LAN, I was anxious to try it out. First time I connected to my DSL internet service, I had the beige bubble in my right bottom hand corner pop up reading... 1.0 GBPS. Ofcoarse, I know this isn't the real speed, but its just what my onboard network device is telling my computer to say. Well, now it's been reading only 10 MBPS... does anyone know why it'd just randomly switch back like that? Since then I have established a connection with other computers through 10 MBPS router, but I can't understand why everything else would immediately change.
I would think that your NIC is sensing the connection and telling you what it is rather than setting it for you. Maybe your router is only running at 10mbps.
I am not sure what you are truly saying perhaps but here goes. Anytime you connect an ethernet connection in Windows XP by default a network adapter such as that is installed to auto sense the max connect speed. Examples are you have a linksys router with an integrated 4 port switch or hub but it only supports 10mbps however your ethernet adapter supports 10/100mbps connections meaning it will show and connect at 10mbps regardless.
Now take your gigabit controller and connect it to a gigabit switch and it will show you connected at the max speed however your cable or dsl modem only supports 10mbps with it's ethernet connection so you still won't ever go above 10mbps theoretical limit anyways through the modem. Most modems even new ones today usually don't support higher than 10mbps with their ethernet controller most in my experience.
Connecting two computers with a gigabit switch and controllers and sharing files you still won't hit that max speed due to overhead. If I remember correctly using off the shelf stuff you can find anywhere the average throughput on a 100mbps network intranet was around 76-89mbps which was good but I don't know for sure about present day stuff and you could probably tweak it somewhat.
Most NIC's onboard or PCI support auto sensing and have the associated indicator lights to show the data rate they are connected at. You can also force the speed manually but it is unnecessary.
