Darrell262
- Jul 9, 2004
Hi, I posted up a message 2 weeks ago about my h50 water cooler having semi hi temps.
It got me thinking about some stuff at work tonight.
I have a 4 core dodge diesel rad in my room on a homemade stand I made outa 2x4's (lol thanks work) I also have the outlet trimmed down to a 3/4 outer and 1/2 inner hose into a ehiem 1250 fish pump (the big boy of yester year) all this is connected into a danger den maze 1 water block which is made for a t-bird cpu. Yeah I know its old school.
It got me thinking.... its all hooked up, just the water block is lying on the floor.
I look at my extra bracket for my h50 (for the corei7 cpu i think) and notice that the circle that holds the h50 is just large enough to cover the water block on the edges. Humm....
I look at another hold down I have for a older 9700 zalman heat sink and that looks like it might work as well....
I am thinking... Why can't I take my h50 off my cpu, and put my maze 1 in its place and use the holder to hold it in place?
What do you guys think? the bracket looks large enough.
Edit/Delete Message
Edit/Delete Message
