thespeakerbox
- Feb 16, 2006
lol
anyways, the GF needs a new monitor. She uses a 17" right now and I want to get her a 22 or 24. What would you guys recommend under 350?
She plays the sims2 and will play the sims3
does graphic design
alot of magazine writing in Word
EDIT:
I recommended she get 2 - 22"s so that she could multi task a little more efficiently. It's gonna be a big help for school she says. However, shes concerned about web design. She likes using her current 17" to check a good resolution fit (for design work im guessing).
Which setup would you recommend
Two 22" s
One- 24" & One- 17"
does graphic design
EDIT:
Two 22" s
One- 24" & One- 17"
