getting my A+ cert
user3657
I have a book from about 3 years ago from an A+ class I took. I never went for my test because I landed a helpdesk job. Now, I dont feel confiedent in being around for a while. I would like to get my A+ so I can start looking for another job.
Im guessing the book I have now is out of date? is A+ alot on customer sat?
yeah, it's out of date.
now I don't know when the test was last updated, but back in my senior year of highschool I had a comp sci class that went through the A+ stuff.
when I finally got around to taking the test, several years later, it obviously didn't have anything about Win98 on the test, and had a lot less about port addresses, interrupts, com ports, etc.
can't remember what all was on mine though when I did take it.
I just took the A+ a couple weeks ago. There were no modern questions at all on it. You'll be fine.
no vista/win 7 questions? or anything about ddr3?
None on DDR3. Nothing on Windows 7. The only thing about Vista on mine (the q's are random) were "Where is the location of the users folder on Vista" and it gave you choices. Of course the correct answer is C:\users\%username%
The test isn't hard but there are some awfully stupid questions. The ones I scratched my head on were policy and procedure ones, like...
"If you are installing software with known compatibility issues, what is the first step you should take?"
1. Make a backup of user data
2. Set a system restore point
3. Read the software manual
4. Ask a coworker for help
... COME ON! All 4 of those are correct depending on the situation! CompTIA has their own opinion on which one is correct. So expect BS Q's that I partially believe are there simply so people do not score 100%.
hrm, do you know the answer? i would say 1. sure 2 applies, but what if it crashes completely, best to make up incase.
It was a made up question demonstrating the awkwardness of some of those that you will see on the test. There were only a couple of these Q's on the test anyways.
I would say 3. If the manual says, "This software does not run on <insert operating system here>," then you just saved yourself a whole lot of compatability testing.
I just passed both A+ exams. I can tell you that most of my first exam didn't even really ask me about ports and IRQs, everything was pretty much situation-based. Most of what you have to know is how to actually solve problems, what steps to take, and where certain tools and utilities are located in 2K, XP and Vista. I found that my first test, the Essentials test, was more than half very much just like the Practical test. I got 840 (93%) on both. I found that my A+ class and studying what I was told to study by study guides actually helped me little to not at all. The practice exams from ProLogic came the closest to simulating the actual exams, so look those up. They're legit and I'm not a spambot :)
"COME ON! All 4 of those are correct depending on the situation! CompTIA has their own opinion on which one is correct. So expect BS Q's that I partially believe are there simply so people do not score 100%."
^ Agreed. Many answers I just felt like I was guessing, hoping that CompTIA agreed with me on what was best practice. Like I mentioned though, the PrepLogic simulations get you in track with CompTIA's thinking of how things should be done.
I can remember taking the A+ about 10 years ago. They seriously used pictures made with ASCI art. I remember a question that asked you to point out which square in the picture represented the CPU. They had one big rectangle with about 5 equally sized squares inside it. It was a crapshoot picking the correct one. It was a ridiculously easy exam though.
Spend your time brushing up on the skills you want to use in a new job. The A+ pretty much gets you in the door at a retail store working in their Geek Squad or equivalent. If you are looking at going into corporate IT, choose a skillset and learn it, so you can accurately portray that knowledge in an interview.
My favorite question that I got wrong when I took my A+ Hardware Exam
So and so calls and complains that her sound is not working. She says the sound is not muted and it was working fine yesterday. What is the first step you should take to troubleshoot this issue.
1. Make sure the the speakers are plugged in
2. Make sure the speaker are plugged into the line out port.
3. Reinstall the drivers.
4. Replace the speakers.
The correct answer was 2. I chose 1. because of the wording of the question. It asks what is the first thing you would do. My thought process with the given answers was, well I am going to check to see if they are plugged in, then if they are plugged in I would make sure it was the proper port. I figured it was one of the those trick questions. I was pretty pissed when I got it wrong lol, but I still passed.
I took the Essentials portion of the A+ a week ago. It seemed a bit out of date. I'm currently studying up for the Practical portion of it. The practice exams have had a lot of Vista questions, but nothing on Windows 7.
I'm in the middle of a network architech program what will get me my A+, Network+, Security+. MCSE and CCNA. After 25 years of working in the field, I find myself in a situation where I need the credentials to compete.
I continue to laugh at people who say the A+ is 'worthless' and only 'gets your foot in the door'. I've never seen an organization say that, only people who already know the material by heart so they assume it's that easy for everyone else. Quite sad really.
I'm not sure about your area but where I live, I read job posting that pay 40-60k/year that require the A+. Maybe that's chump change in some area's but not where I'm from.
Then you haven't been job searching for anything above a super-entry level IT position. Granted, I'll give you that some things vary geographically, but I've done a fair amount of interviewing in my career, on both sides of the table, including my own job searches for Exec level positions, down to the entry-level tech support job my wife has now. There's nothing laughable about it...that's just the way the job market's been for the past 6 years or so that I've cared about it. If all you have is the A+...you have nothing substantial and will be passed over for most jobs. If you have more than just the A+ such as a defined skillset or experience, they will outweigh the A+ anyway.
Whether or not you have certifications must differ from area to area because in every thread you will find people reporting completely different attitudes toward experience, education and certification. Down here in the Tampa area having a certification in your area of work is a big deal. It's pretty popular where I'm from too (DC-Baltimore area). In other areas, people report that their certifications do not matter. I have a teacher who says he would hire someone based on what they can prove they know and not what their certification or education says. I asked him where he was the whole time I was applying to tech jobs before I started this expensive schooling LOL.
I can tell you that ever since I put A+ in my resume I've been getting a lot more further contact with prospective employers. I want to be a regular tech though, I have no desire to be a network administrator and such. I definitely won't be going the Cisco route. I took the class and managing switches and routers is not for me. I like to get dirty, even if I won't make as much money as the Cisco guys. If I was willing to do something I didn't care for to make money, I would be studying something much more lucrative.
A lot of people scoff at A+....saying it's too basic, too menial, too "stupid" ..really only for people who will work at geeksquad or bestbuy upgrading memory of Pavilions and eMachines from home users.
I'm not of that camp...I'm a fan of properly building a foundation of your computer courses starting with the basics. Just like in school...you start out with all the "101" entry classes..and you move on up from there. Start by building a good foundation. If you already know a lot about computers...great, you'll pass the test easily.
On the flip side...I've seen so many of what I call "paper certs"...these self appointed high end computer guys that skipped the basics...and they did braindump/cramming sites to only get those high end certs to make themselves look like they know their stuff..and you put them in front of a real world scenario that may require some basic knowledge..and you see that they're really so stupid they can't change a lightbulb...or even properly change out a network card in a server. I've seen that way too many times. Don't be one of those.
That can be the case some times where some kid has an A+ with zero experience. But as I pointed out, that's not always the case. I've seen several positions which require 5-10 years, and A+ or equivalent that pay well over 50k. If it wasn't required, they wouldn't say 'required'.
Despite twenty-five years experience working with computers, it's to the point where you need the A+ just to be taken seriously. I resented having to pay the money and take the tests because I know computers inside and out. But having it was the difference for me between a "job" and a "career".
Not always. One of the first lessons we always taught in internviewing and resume writing was that the job's "requirements" were for their absolute ideal candidate...and not everything is set in stone. When I used to do the interviewing from the employer side of the table, I would gladly consider people who didn't meet all the requirements. What you know, and how you came to know it are more important that what papers or certs you can show me. When my wife was job searching three years ago for entry level, you still didn't see A+ mentioned that often. She has no cert at all, and had no trouble getting interviews for jobs that "required" them. In fact, her current job she's had since then "required" it.
The bottom line from my experiences....if you have absolutely nothing else to put on your resume, maybe it isn't a bad idea, but I wouldn't spend much time or money obtaining it. I'd rather spend the time on self-learning, and making special mention of that in an interview. I always gave the self-taught people a second look, because it showed me they had discipline and drive. If you have a couple of years experience, that would far exceed the A+ cert. if it doesn't, you should seriously question the mindset of the hiring company.
I got my A+ a few months ago, and like NoForgiveness, I've gotten a lot more contact from employers. I'm in college right now(graduating next September), and I want to start looking for an entry-level job far before I graduate. I don't have much paid experience, so I needed something that says that I have at the very least a basic understanding of computers. I'd also like to pursue higher certifications in the future such as CCNA and/or MCITP, so I figured A+ would be a good jumping off point.
Paid experience is always better, but that can be said in regards to any certification including A+, CCNA, MCSA, etc.
Just to add, getting this cert will not hurt you. Some employers require it, some don't care. I would encourage you to get it. Obviously the job market is becoming more saturated and anything you can do to make yourself stand out will help.
A+ cert is a great place to start.
Well said. The modern IT professional never stops learning and continuously takes certification exams. Though I'm pretty happy that I made it on time to never have to take the A+ again. Everyone else from now on will have to take it every 3 years to remain active.
My A+ even adds onto my engineering degree. You would be surprised how many of those people who are so sure of themselves fail it.
I think its great. Plus if you wanted to start your own company, its reassuring to clients.
A+? Don't waste your time... unless you just want to work in tech support.
i thought that starts feb 2011?
No way dude, life doesn't work that way. Life is a 4 option choice with 1 right answer. ;)
Yeah I was studying for the A+ test and came across some example questions that made me think that all options were acceptable.
Good to know. Thanks for the tip.
Also, sorry to resurrect such an old thread, but I've been wanting to get my A+ cert lately, and figured bringing back a semi-old thread was better than making a new one.
It's true that I didn't mean exactly NOW when I said 'from now on', but soon enough...
The deadline is December 31, 2010. So Jan 1, 2011, no more certified for life.
Info here: http://www.comptia.org/certifications/listed/renewal.aspx
What I'm happy to know is that I can still take Net+ and Security+ too. I am about to schedule my Net+ date. Will be going for Sec+ ASAP.
Wow, that's shitty. :( Wish I had looked into this sooner.
I was slightly discouraged when I heard about having to retake the test every 3 years, but honestly, it really shouldn't be an issue as long as you stay on top of things.
Oh, and talk about BS questions, I was taking a prep test, and one of the questions was "Intel is generally more reliable and performs better than AMD. True or False?" Honestly... how the hell do you answer that? I put true because right now, Intel currently owns the performance crown in BOTH the enthusiast/high-end price segment AND the midrange/mainstream segment (Last I checked, SB Core i3s were on par with AMDs Athlon II x4s in applications that weren't heavily optimized for multiple cores or threads, namely Photoshop and such), and the answer was marked wrong. When I tried to contest the question with the instructor, the guy called me an Intel fanboy, despite the fact that I own an even number of Processors from both manufacturers, then said something about how AMD kicked Intel's trash back in 2004, but the test did not say "Intel has ALWAYS been better than AMD. True or False?". It irked me to say the least, and I've been needing to vent. Maybe he just can't stand a 17 year old contesting his knowledge in front of the class.:rolleyes:
Well, take it from me - You won't see a question like that on the exam, so don't worry about it. There are no true/false/matter of opinion questions on the A+, it's all 4 question multiple choice. It also sounds like you need to find a different instructor if possible; somebody who would pick that kind of argument with you has probably fed you some other B.S information as well.
Get a more legit practice exam from a certification guide. I found that those were pretty on par with the exam questions. If you read a good guide a few times (I like Sybex and Meyer's stuff) you should be fine.
I took it last November (as well as net+) because I never bothered with it and wanted to get them before the 3 year expiry. I did 200 questions in about 35-40 minutes and got an 875/900 and 870/900 on the essentials and practical, respectively. There were probably 4 questions that I found to be worded awkwardly that I know I got wrong. I was actually upset that it was easy after I put a decent amount of sweat into studying, lol. I didn't use any braindumps, cheating, or the like... I just really applied myself towards the material, even though it wasn't necessary.
That said, a pass is a pass, and the rest is really just for your own piece of mind. The important thing is that you're learning about the hardware and the OS rather than how to take the exam. If something piques your curiosity when you're studying it, find out more about it. Certs can be an excellent learning tool - if you study for them correctly. Unfortunately, many people don't, and that's what gives them a bad name...
Learn what you need to learn and get experience. I work in an enterprise environment and most of the hardware dudes don't even have the A+ cert, 2/4 of the network techs do not have the CCNA (even though our shop is completely cisco), etc.. So they don't necessarily matter - you just have to know the material and get past the HR department :).
Now I'm studying for CCNA, which makes A+ feel like a complete joke :p ... I'm glad I got it though.
When I first interviewed with my current employer he told me that some places want a certification and some places don't care and want experience.
All in all it really isn't going to hurt anything by getting it. (I don't have one).
This is an entry level cert (it shows you know the basics), if you still need to rely on it after 3 years - you have much bigger problems and I suggest IT isn't for you.
I look at it this way. My employer doesn't look at certifications and I don't think I know anyone here with any. I just went to a nice college to get a BS in Software Engineering and the degree plus the school/gpa is what all the employers here look at.
They realize that there is no way in hell you would have been able to get the degree and a good gpa from a school of a certain level if you didn't already know all the stuff on most of those entry-level certifications anyways.
I'm only in High School, and I figure I have a better chance of getting an entry level position or internship if I have at least my A+, Net+ and Security+ certs, people are generally pretty skeptical of teenagers, so I could use all the help I can get.
Ah, but if you let it expire, you can't technically say you are certified anymore can you? And why wouldn't you want to spend the money once, as opposed to multiple times?
Because later down the road, you should be certified in something else besides A+. The only reason to recertify in most cases is if your job requires it. The rest is more effectively learned via experience.
