Generic rate my build thread.
Moshiach
Hi, been lurking the forum for a bit and thought I'd ask a pretty typical request. I'll be getting a new comp in around 1-2months, it will be mainly for gaming, a lot of current games and and future games such as Crysis, Quake Wars, Starcraft 2, Warhammer Online, etc.
Motherboard: Asus P5k
CPU: Intel E6850 (when it comes out)
Hard Disk: Western Digital 500GB (not sure on how much boost installing the OS on a raptor would give)
Video Card: Leadtek 8800GTS 640MB
RAM: Corsair 2 x 1GB 1066hz PC8500
Monitor: Benq FP222W (does a larger monitor strain the video card? should I settle for a 20"?)
Case: nfi
So any input is very welcome, upgrades, downgrades, better brands, alternate pieces, etc.
Seems like a good build. The only issue might be with the 8800GTS card. It seems like these cards (8800 GTS/GTX/Ultra) are struggling with some of the DX10 game demos. I personally would not recommend getting one of those cards right now, especially not until the dx10 games have come out. The 8800 series cards are 6 months old, nvidia will most likely revise it in Q4 '07. I think you should stick with a higher end DX9 card and upgrade when the DX10 games come out.
Be sure you get a good PSU. You have some quality parts there and you don't want them to die due to a bad PSU.
Also if you plan on OCing spend some money on an aftermarket CPU cooler.
From what I read, the issues with the 8800 series seems to be more a software/driver thing rather than a hardware thing. Either way, I'm planning on keeping the box and everything in it just in case I want to sell it when the GeForce 9's come out. Don't plan on overclocking either.
Can you recommend a PSU for this build?
Any advice on a Raptor would also be great.
Kinda hard to recommend or shoot down parts if you don't provide us with a budget.
Oh and Raptors aren't worth it IMO. They're more of a luxury item than a real essential. As for power supplies, it depends on your budget and what you need for that budget.
$2500AU is my budget, that build at the moment stands at about $2200, that's not including a case, plus I'm only estimating the E6850's price.
Thanks for the heads up on Raptors.
Yes, Raptors make little to no sense unless you just have too much money and can't figure out how to spend it after ordering two OCd 8800 Ultras for SLI... or similar.
The card should be fine. Get a GTX for the extra stream processors (128 vs 96) if you're really worried about longevity, but the 640MB GTS should do fine for you.
People overlook the fact that Lost Planet is not a native DX10 or even PC game -- it's a ported and patched XBox 360 game. Are framerates lower than I'd like? Yes. Will they go up? I'm reasonably sure they will. You have to remember that if any developer was working with DX10 until only a couple of months ago... the 8-series was their development platform. Or at very least, their target high-end platform. It should last for a while. And if the 9-series is as awesome as people let on, sell the 8800 and buy one.
PSU: PC Power and Cooling Silencer 750 Quad. Plenty of headroom, and 60 amps on a single 12v rail. $200 or so.
Great replies, keep them coming.
Another question, will there need to be any BIOS changes to the motherboard for it to support the 1333 CPU?
Most likely not since the P35chipset has native support for 1333FSB. So no worries about that.
I recommend the Corsair 620HX power supply if you can find it in Australia. It's an excellent power supply.
