General Use, Low Budget Office/Productivity
Xonim
Buying/building a computer for my parents & sister for Christmas because I'm tired of them complaining about how slow theirs is. They're currently using some old HP with a Pentium 4, 40GB hard drive, and either 512MB or 1GB RAM. Simply put, I can't take their PC anymore :D I know the answer is going to be "buy a prebuilt," but I think since I'm reusing an old SSD, I can use better parts & leave room for future upgrades for roughly the same price since I don't need the HDD. However, I do need the tower to be about the size as a prebuilt Dell/HP tower, or smaller if possible, to fit inside their computer desk.
I should mention that knowing my parents, this will be something they will want to keep a minimum of 5+ years.
Web browsing, email, office/productivity type stuff, Quicken
$300, yes (have Shoprunner + Amazon prime), not set in stone
Minnesota, 20 min drive to Micro Center
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Theword "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, Motherboard, RAM, Case, PSU, DVD burner
160GB Intel 320 SSD, monitor, keyboard, mouse, speakers
6) Will you be overclocking?
No
22" OR 24" 1920x1080, I know the resolution is right, don't remember for sure the size
Nowish
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing special, Intel graphics are fine, USB 3.0 would be nice but not required. Must be mini ITX, micro ATX would work if the case is no larger than a standard prebuilt case.
Win7 HP 64bit
Case-wise I've been looking at the Antec ISK cases, but people seem to be split on whether they're any good or not. Newegg has the Lian Li PC-Q07 for $45 the next couple days, but I'm at a loss for what to use for a power supply in something that small. I was thinking PicoPSU, but I've never used one.
($172) i3-3225 (only because of the $40 MB discount) + Gigabyte GA-H61N-USB3 mITX Motherboard @ MicroCenter
($30) 8GB of whatever RAM is on sale
($20) DVD Burner
Leaves $80 or so for case + psu, $90 if I drop to 4GB RAM. Looks like that MB supports IB chips, but may require a BIOS update depending on what version it ships with. I can pull a SB chip from one of my boxes if I have to.
Would the lower budget Celeron G550 be sufficient ($35+tax)? Motherboard would then be $80-85 shipped for a total of $120.
The cheapest PSU we tend to recommend is the $45 Corsair CX430 V2 430W PSU. However for that kind of case, a modular PSU is highly recommended. The lowest priced modular PSU I can tentatively recommend is this $65 Rosewill:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132
With that said, people have used non-modular PSUs in that Lian Li before but have noted that you'll have relatively poorer cooling and virtually no space as a result.
Thoughts on this PSU?
($50 after MIR) PC Power & Cooling Silencer MKIII 400w
Otherwise, this one: ($70) Seasonic M12II 520w
EDIT: And is the i3-3225 combo worth $50 over the Celeron G550?
Think I'm going to go with something like this then:
($172) i3-3225 + Gigabyte H61N-USB3
($70) Seasonic MK12ii 520w modular PSU
($45) Lian-Li PC-Q07
($34) G.Skill Value RAM 2x4GB
($16) Samsung DVD Burner
$337
So far so good.
However, check out the SG05BB-450-USB3.0 if you want better cooling.
If you're ever going to play a game, YES!
I can tell you from experience that even older games are largely unplayable on the old HD 2000. HD 4000 is a huge improvement!
Also, the extra threads may be a good investment for the future, as more threads make a heavily-loaded system feel smoother.
For "future proof" an I3 3225 is worth $50 ocer a Celeron. Celeron has Intel HD video, Pentiums HD2500, 3225 HD4000 which falls between a GT440 and an HD 6670 I think.
Plus you get fast, and add two threads.
Power supplty has to last 5 years, but most use won't be much above idle.
I would be happy with a CX430 but cables are long, do not know if modding or cutting away would void warranty.
Antec VP-450 $38.99 same song different singer
http://www.amazon.com/Antec-VP-450-...2504393&sr=8-9&keywords=power+supply+computer
Black Friday should offer a sale price
Seasonic adequate $49.58
http://www.amazon.com/Seasonic-SS-3...=8-42&keywords=power+supply+computer+seasonic
Antec Earthwatts EA-380D $43.69
http://www.amazon.com/Antec-EarthWa...ie=UTF8&qid=1352505254&sr=8-14&keywords=antec
Rosewill Green RG430-S12 $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182202
case with power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147131
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108396
http://www.amazon.com/Antec-ISK-310...ie=UTF8&qid=1352505491&sr=8-99&keywords=antec
So far so good.
I like the case, Anandtech liked the power supply. I'm going to need to go measure the cubby in their desk next weekend to see if it'll fit.
