General MoBo performance question
Tanatz
What exactly makes one motherboard perform better than another with the same CPU / GPU / Sound Card / PSU attached to it? i.e. what spec. should I be looking at during comparison?
With Intel chips, how the memory controller works between different Intel, SiS, Via, Nvidia chipsets along with basic IDE/SATA/NIC performance.
AMD...pretty much all chipsets are within 1% of each other due to on-die memory controller, so other things such as IDE/SATA/NIC performance are the differences.
In general, do you guys use a separate NIC card or do you all use the integrated NIC?
Also: sound cards. I use an Audigy 2, does everyone use a separate sound card to save CPU cylces? Will dual core CPU's help with on board sound? I can't shake the feeling that my Audigy 2 is actually a downgrade from the on board sound on my mobo.
I use a USB wireless adapter, so I don't even use my NIC :). Most people I know use the onboard one with no issues. Some use onboard sound, some don't. I use onboard, but only because I don't need anything super right now. I got a 5.1 card in my last computer because of CPU cycles, but it didn't make that big of a difference.
Audigy2 is better than any onboard sound I know of. Even the MSI board with the creative chip is only SB Live 7.1 or Audigy1 and they are the best onboard out there.
