General Consensus: Gigabyte Mobos = good or bad?
Suprnova04
Just wondering what people think about gigabyte motherboards. I'm putting together my first PC and was curious if these are worth looking into or not. Also, what are generally acceptable brands? I'l be using this for gaming and college stuff.
Here was a good summary of Gigabyte motherboards quoted from a [H}ardocp review of the Gigabyte SLI board.
Kyle's Thoughts:
Overclocking on this motherboard was a big letdown when compared with most of the other nForce 4 boards we have recently reviewed. A maximum stable 250MHz FSB, as Morry pointed out, is not acceptable in the enthusiast realm. That said, this is the first Gigabyte review you have read on HardOCP in quite a while, and the reason is that this is the first “reviewable” board we have seen from Gigabyte in quite a while. By “reviewable,” I mean one that will stand up to our testing standards without turning into a 100+ hour project. We find there are many things to tinker with on many motherboards in order to get them running stable, but in the past, Gigabyte has continually delivered motherboards with severe lackluster performance. With the GA-K8NXP-SLI, they have broken this cycle. This motherboard is not for the hardcore enthusiast and likely not even the noobie. It did however work well at stock settings for us.
They work fine at stock settings, but for some reason don't work the way an enthusiast would want them to run (OCability, etc.). They are usually slower than the rest of the boards, but they usually have a good bundle of goodies if you're into that kind of thing.
ASUS, MSI, DFI, Abit, and maybe Epox are the boards I would look at.
Gigabyte is a nice company if you don't care about Overclocking, if you do, look at Asus for some decent OC'ing. You want extreme OC'ing, go with DFI or Abit. I won't touch Epox considering every Socket A board I used of there's failed to work or crapped out within a few weeks...no, I'm not jaded at all.
Epox is usually a little cheaper than the other brands, but I have heard complaints about them also. I had a couple of them that have worked fine for months now (s754 variety). But I have more faith in ASUS, MSI, Abit, and DFI. Actually, I had a crappy DFI board, but my ASUS, Abit, and MSI boards have all been solid to this point ;).
