Geforce rtx 2080 ti xc
ralphie1313
Hi can anyone tell me what size fans are in this card its dual fan one of them is starting to break down so i want to order a new fan but can not find the size anywhere thanks!
If you take the fans off of the heatsink, should be able to read the part number off of them and then search for replacements on ebay. You probably wouldn't go by the size, since the fans are a custom made assembly on most cards, even if they're all similar sizes.
You may also be able to buy replacements straight from EVGA, either for a few dollars, or maybe even free if the card is still under warranty.
Pulling the fan to get the model is your best bet.
I suspect these are the fans you need from the listing title EBAY
Searching the fan model # in that link pulls up more options. Just keep in mind it looks like most cards use 1 fan with a long cable and 1 fan with a shorter cable.
