GEFORCE GAME READY DRIVER 358.28 WHQL
FrgMstr
Just Plain Mean
Staff member
New v358.28 WHQL NVIDIA driver this morning. Thanks blah blah.
Game Ready - Provides the optimal gaming experience for Agents of Mayhem
Game Ready VR - Provides the optimal gaming experience for Killing Floor: Incursion
Yeye, time to reinstall their telemetry crap!
I wish they would update the audio driver. I'm sick of having to shut my receiver and monitor off and back on half the time when I unplug my headphones (from the motherboard's Realtek chip). I never had any problems with that at all with my AMD cards and I'm pretty sure it's the same Realtek codec inside nVidia's cards.
Graphics cards dont use a codec for audio, they are simply a transport.
The device plugged into the gfx card has the codec.
Your problem is likely OS based.
I just wish they would reduce the package size. I mean it is approaching half a gig.
Well, whatever it is, I don't think the problem has anything to do with the OS. I used several AMD cards, two of which were used with Windows 10 (the same as my current GTX 1060) and never had this issue, ever.
I started a thread awhile back about the HDMI audio silent stream bug and mentioned an alternative to AVR Audioguard and someone mentioned they wish it had the feature to restart the audio drivers like in AVR AG. I never saw a use for that feature, but now I know why he wanted it.
Why does this keep coming to my mind lately when a new driver comes out?
^^ Amen. Out of control. And install time is absurd.
I think they purposely slow down the install so they can keep their advertisements exposed for a longer period of time because apparently many will just sit there during the install and stare at the loader window
any reported issues with these?...with Nvidia it seems a hotfix driver has been released for the past 6 months or so after every new WHQL release
Receivers give you a lot of advantages but have a lot of potential pitfalls. You might benefit from some sort of EDID emulation - either from a hardware device like the Gefen HDMI Detective ($100 give or take) or there are software tools that can do the same thing - trick your PC into not losing the HDMI connection.
Another thing that can help in some situations is to split the HDMI signal and send it in parallel to the receiver and monitor rather than to the receiver and on to the monitor.
For me, the HDMI detective was more than worth it - no matter what happens on the audio side, my PC always thinks I have a 7.1 capable device attached.
But wouldn't something like that prevent the Realtek chip from taking over when I plug my headset in? As it is, I can set HDMI audio to default and it stays on, but then the sound comes from both the speakers and headset.
I reckon antivirus developers do the same thing when you uninstall their products, how on earth can the uninstaller just sit there doing nothing for a good two minutes or more? I swear they deliberately do it to piss the average user off.
It might. It depends on how you setup your default device.
1. It's not that hard to switch inputs once you get used to it.
2. You might try using the headphone amp on the receiver.
3. Not sure why the audio is coming from two devices but see #2 as potentially solving this issue as well.
