GeForce 6800 Non Ultra DOOM 3 performance
Brent_Justice
Moderator
For people with 6800 non ultras I'm curious to see what kind of quality settings you have chose in DOOM 3 and performance you are getting on what system you have.
Thanks
P4 2.8C@3.4
Asus P4C800-e
evga 6800 128mb
2x512mb Kingston HyperX BH5
36gb Raptor
vsync off
No AA
1280x1024
Low - 64.6
High - 57.3
I ran all these with vsync on. No AA
LOW QUALITY
1024x768 - 54.7
1280x1024 - 45.3
MEDIUM QUALITY
1024x768 - 54.2
1280x1024 - 44.7
HIGH QUALITY
1024x768 - 48.6
1280x1024 - 39.1
I was on a Leadtek 6800nu for a few days and was able to play at 1280x1024 high quality very comfortably on my system. This being at stock video clocks as well. My ASUS V9999GE should be in early next week, and I'm thinking it will do even better.
my 6800 comes in on tuesday, i'll let you know next week
I get a steady 40-50 fps @ 1280x1024 on medium. I have 1 gig of ram and an Athlong 2500+.
No offense bro, I'm just curious, why'd you get a V9999GE rather then a 6800GT? They're practically the same price, except the GT has 16 pipelines while the V9999GE has 12.
Hey, that is my exact computer! =D What kind of scores do you get in AquaMark/3DMark03?
Yes, I know that the GE only has 12 pipes but it just looks so damn cool. Also, it was readily available right when I had the cash to get a card in that price range, so I went with it. With all the talk of the 6800 pipe mods going around, I might end up with a GT anyway. ;)
Look at her. So sexy.
heres mine:
rock solid at 350/800 no artifacts doom 3 at 50+ FPS on system below
My eVGA 6800nu @ 350/775
2700+
1GB PC-3200
Asus A7N8X-X
Doom 3 @ 1024x768 high quality, no AA, 39fps
Are you sure that's a 6800nu? Not even the GT needs 2 molex connectors..
Yes, it's a 6800nu core. If you do some research you'll see that the GE is unlike any other card out there right now. It's almost half NU / half GT.
Man I totally agree, it's the most beautiful 6800 out right now, I would sex it if I could. But alas, 12 pipes just turns me off =S
GeniusInABottle, How much for the asus V9999GE ?
Do you have a link to sites that have it in Stock ?
53 fps @ 1024x768, Nvidia "high quality" setting, D3 high setting + 4x AA
62 fps @ 1024x768, Nvidia "high performance" setting, D3 high setting + 4x AA
2.4C @ 3.25 / 1 GB dual channel PC3200/ ASUS P4P800
PNY 6800 oc'd 385/850
Upwards of $400USD right now. As for sites with it in stock, head over to pricewatch and enter "v9999" in the search. A bunch of vendors will come up. Hope that helps.
All STOCK.
Sony 2.4Ghz
1Gb Ram PC2100
Audigy
Geforce 6800 Standard
1028X768: No AA/AF
This is my frame rate after the first run that seems to be different because of loading:
44.8 VSYC OFF
39.4 VSYC ON
It's plays well until I get in a room with a lot of baddies. I think when about 5 baddies all come at me at once is when the frame rates jump down to about 12-15FPS. This doesn't last to long if I get rid of all the baddies before I die.
GeniusInABottle, Thank's , Even if it is a 12pipe Non Ultra/GT 6800, won't the extra 128meg's help smooth out choppyness.
I think a 12pipe 6800 has the speed and bandwith to take advantage of the extra 128meg of ram, it's not like a 256meg ati9600pro or a 256meg nvidea 5200 or 5700 I think the extra memory will work good on a 6800 non Ultra/GT...Have Fun with it.
Yes, if you look at this article it shows the extra 256mb helping more and more as detail and resolution are cranked up (no surprise). And keep in mind that they went so far as to slow the card down to normal 6800nu core/mem clocks as well. I could only imagine what the extra speed/bandwidth would add on top of that.
But you're still getting a card with regular ddr instead of gddr3 for around the same price....makes no sense to me. :confused:
No, actually it's gddr3, just like the big boys.
1600 X 1200 8XAF 2XAA High Quality = 57.3FPS (Average of three timedemos )
Zachary
specs:
dual athlon MP 1600+ procs
geforce 6800 nu
512 megs pc2100
I run at 1600x1200, 2xAA, 4xAF, all extra features on, except V-sync.
I get frame rates between 30 and 60 (sometimes above 60 for some reason.)
sometimes it dips below 30, like to 25, but it still feels very smooth at those frame rates with my dually.
2700+
1GB PC-3200
Asus A7N8X-X
Whoops...had vsync on...54.9 fps :D
btw, where can I get the timedemo?? I'm not sure if it is warez...if it is then don't tell me. lol
:p
:p
Just pull down the console (alt + ctrl + ~) then type, timedemo demo1, then enter.
I have the v9999ge, basicly its exactly a GT but with 12 pipelines, memory and core speed is the same 350/1000 and it has gddr3 memory like the GT... it also has 2 molex connectors, i OC the core to 445mhz and memory to 1170mhz. i get over 11000 in 3dmark.
for those of you with the nu and 512 mb of system ram do you notice any pauses in Doom 3 when using High IQ like when opening doors or approaching a lot of bad guys ? Because of the 128 mb of ram trying to load new textures onto it ? Anyone notice that ?
Are you sure that you don't just need to turn off fastwrites? That sounds EXACTLY like the fastwrite issue... I had a 9600 Pro with 128MB and it ran fine after I turned off fastwrites, but, did precicely what you described while I had that turned on.
BTW, I've read that AGP aperature supposedly isn't used much anymore, but, then I read here that increasing it helps many games like Doom 3 (perhaps especially Doom 3.) Does it just simply depend on how much VRAM you have or what? Because I didn't really notice much difference no matter what I set it to on that 9600 Pro, but, then again, I didn't test TOO thoroughly.
Leadtek A400 6800nu
390/950
Doom 3 1024x768/High Quality/4xAA/8xAF - 56.0 fps (VSync Off)
:p
I don't understand how Warez even entered your mind when talking about ID Software and the concept of a "timedemo". :rolleyes: Kids.
EDIT: Ack, seems I just get dumber the later it is. (Hey, give me a break, I'm on extreme lack of sleep mode.)
Disregard this post or else! What? Er, I don't know, but I know I won't like it! Er, you won't like it. Never mind. Be quiet!
xp3200+, 6800nu(325/700 and 400/900)
56/63fps 1280x1024 high
66/68fps 1024x768 high
68/68fps 800x600 high
1280*1024, all options set to max in doom3 except its high quality not ultra. in drivers set to high quality textures. vsync off. 61.77 drivers
timedemo demo1 usecache: 44 fps
when its overclocked and is recognised as overclocked (1/10 chance) , 60 fps.
edit: for some reason after uninstallin the 66.0 drivers and reinstallin the 61.77 im gettin a average 4-5 fps increase in doom3. this happened once beforre but happened when changin to 62.20(3 fps increase that time) , after goin back to 61.77 then trying to reinstall the 62.20 i was gettin the same 44 fps.
