TelemoniusajaX
- Feb 7, 2007
Just out of the blue this computer stops recognizing its video card, It was an expensive one to biuld so I decided to do a little investimigation. Come to find out that its not the video card burning out. In fact, the vcard is working perfectly. By process of elimination (reinstalling drivers for the motherboard and the card, messing with bios config, updating bios, clearing cmos, etc.) it turns out that the pci-e slot is not working properly on the motherboard. To ensure that this was a software problem, instead of hardware malfunction, I reformatted the computer. Success! The pci-e slot works again and recognizes the vcard. However, at spuratic moments the problem returns. That is, whatever monitor is hooked into the computer just looses its signal, There is no rhyme or reason to its occurence. I thought it might be an over heating problem but the computer can run for hours or seconds before the problem reoccurs. Any suggestions? Also, it should be noted that the onboard card has been working fine.
specs:
nvidia geforce 6100-m9 motherboard
geforce 7600 gt pci-e video card
specs:
