Gateway XHD3000 DVI vs HDMI
Zepharus
I have the ability to connect it via Dual Link DVI or HDMI with my GTX 295 Which will give me the best picture, control and results with my PC? Thanks in advance
Dual link DVI will give you full resolution. HDMI does not support 2560x1600@60hz. This resolution requires a dual-link card and a dual-link DVI cable.
Your GTX 295 supports dual link DVI out, so use the included DVI cable with the XHD3000 for best results.
qft, use the hdmi for a xbox360
Actually..the HDMI 1.3 chipset will support 2560x1600, but the XHD3000 as you know it, only has a 1.2 chipset limiting your max HDMI resolution to 1920x1080.
I believe the only way to get a WQXGA signal to the monitor is via DVI_D..unfortunately.
I have no idea why they would not include a 1.3 chipset on a 30" monitor
