twogunpete
- Mar 13, 2006
ok! i am at my wits end.i have been wiping and re-installing windows on my friends gateway model :gt5411e ,and after everything installs with the factory restore disk a program pops up from gateway that says it needs to update files on the pc.i went ahead and let it do its thing (one of the files it updated was the bios) when it reboots all i get is 3 beeps from the mobo. after some searching i found that it means that the first 64k memory failed ,so i tried resetiing c-mos.i followed the instuctions on gateways site and still get the beeps. has anyone else had this problem ? am i not leaving the jumper on long enough ? i know you guys can fix this for me.
edit: i also tried removing the battery for 15 min.
