Asferlazzo
- Mar 1, 2007
I just bought a new Gateway FX530XL with the Intel Core 2 Duo Extreme QX6700 Processor. Gateway offers this system factory overclocked for $100 extra. I wasn't really thinking at the time of the purchase and i fergot to add it onto my order.
Can someone please run me through the correct way to set this processor to the 3.2Ghz that gateway sets the factory ones to?
I did it myself once and thought everything was correct until the system started giving me the blue screen of death with memory dumps. I must have done something wrong. I have the Intel® 975X Chipset.
I know you are supposed to first change the jumper position, then start up the pc, while in the bios tab select performance,......and then i get lost. Last time i set the processor multiplier to manual and then 12.
Hopefully someone knows how to do this correctly. I don't want to mess up my new computer. Thanks!
