Ok, I'm now on my second monitor (which I'm about to return). First was a Jan 07 and had a back light bleed in the lower left corner and the inverted ghosting. Second one (Feb 07) doesn't recognize 1920x1080 (which the Jan 07 did) over the VGA port. I had my 360 hooked up via the VGA and set to 1920x1080 (1:1) and my PC on the DVI connection. If I set the VGA to 1920x1080 on VGA on the Feb 07 monitor it kept recognizing it as 1280x1024 and cutting off half the image. Hopefully the third will work better. Also, how is everyone getting their 360s to run 1080p? Mine won't work over the component connection.
Is your monitor a MXH72 and does it have inverted ghosting?
I am using VGA to get 1080p with 360 and it works fine.
By that do you mean you are using the Xbox 360 VGA cable and setting the resolution to 1920x1080?
After using this latest monitor I've notice that the left side of the monitor is a bit lighter than the right. If I set the monitor to just have a black background it almost looks as if there is a light reflecting off of the upper and lower left corners. That will drive me nuts. I think I may take another trip to Best Buy.
Yeah using the VGA cable I get 1080p with proper scaling and it looks amazing. The screen should not be brighter on one side btw.
Have you tried VGA out from your PC?
That is really strange, though it is running a different OSD version than the Jan, I wonder if they screwed something up with 360 functionality.
Annoying. You have video adjust on 1:1?
Tried both 1:1 and Zoom to no avail. I'm taking it back tomorrow. Looks like Gateway broke the 1920x1080 VGA as of the Feb 07 monitor with the 5.5 OSD.
I'm not sure if that is the case, my friend has a Feb. model, I might bring my 360 over there to test it out. Odd that the Jan 5.0 OSD had no issue with 360 but now the Feb 5.5 does?
Try another and post your results, it would be interesting to see if that really is the case. Wouldn't make a damn bit of sense though, the scaling features shouldn't break just because of a small software revision but you never know, it doesn't take much to break a feature.
One of the greatest aspects about this display are it's awesome scaling functionality with consoles, that would be a major blow if they fucked up 360 and 1080p. I think we need at least one more Feb to fail the 360 test before coming to that conclusion.
Oh man, that's not cool.... One of the reasons I like this monitor is for XBox 360 gaming on it. I've got that gateway logo stuck on the screen for a few minutes after powering up the lcd problem. I was going to rma but rather have that problem then no 1080 display.![]()
wait
so that is an issue?
Ok, basically this problem is for when you powerdown you turn on pc and then turn off monitor and then turn back on monitor later on.
I like to turn off my monitor while leaving my pc on when I'm away from it.
There is a Big ole Gateway logo faintly stuck in the middle of the lcd screen and you can't access the menu from the lcd for about a few minutes. After a few minutes things go back to normal, but fvi logo remains stuck on screen for a few minutes.
I don't get that.
I don't get that.
I understand the issue, I just don't have a problem like that.
lol
Yeah I do that all the time actually. My PC is usually running, downloading stuff, then I power off the monitor. When I return it powers back on right away. Although I am running my DVI cable into an HDMI switch box, using a DVI to HDMI cable. This allows me to use the digital port for my PS3 as well.
Wow, all these stories are really making me not want to buy an LCD. I can't seem to find any model currently available in a 24" that doesn't seem to have a large contingent of issues surrounding it.
