Austin said:....4) Profit - you mean ebaying it? Go for it, but I doubt you will make too much.
does this rig even have pci slots? I'm only seeing pci-x, a totally different animal.roninblade said:no they work good for dvd playback, checkout newegg, u can grab the top of the line PCI card for around $60, probebly will be the 9600
/edit heres a good card for this:
http://secure.newegg.com/NewVersion/FeedBack/CustratingReview.asp?item=N82E16814130188
Anyone kno if this server would make a good linux system?
PCI-X can use standard 32bit PCI cards. PCI-X is backwards compatible with PCI...ninethreeeleven said:But what about Audio? Can you mod a PCI-X slot to use a PCI sound card? Or video card?
schnell said:can i throw an ide hard drive in there? it only lists sata channels
can i put non ecc ram in there?
DriveEuro said:PCI-X can use standard 32bit PCI cards. PCI-X is backwards compatible with PCI...
Do people really not already know that? Wow
Jelic said:Waaaiiiitt WHAT?!?! PCI-X, the short slots, are backward compatible with regular PCI? So if you have a PCI-X 1.0 slot that's VERY short, you can still stick a sound blaster Audigy 2 ZS in it and it'd work?!?!
ya, thxJelic said:Hah oops, seems like I got confused there, thanks for clearing that up.
