Gaming : WOW, SC2, COD and CS:GO
Special-K
This is for another friend.
So title says it, I'm looking for hardware that will handle these game at 1080p with good quality. I know CS:GO is not out yet so just ignore it... but he will play this.
1) What will you be doing with this PC?
$900-$1250 CAD with monitor
3) Where do you live?
Quebec, Canada
4) What exact parts do you need for that budget?
CPU, Mobo, GPU, Ram, PSU, Case, HDD, Monitor, optical
none
6) Will you be overclocking?
I don't think so, he don't really know how.
20-24" 1080p LED max 200$
Newegg and N C I X
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
none
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
i have both, just tell me the one I need to install
Some of my thought, I can't decide the good one
I5 2320 $180 vs I5 2500K $220
GTX 560 vs GTX 560 TI vs GTX 570 (cheapest of each model)
then I guess a H67 with the 2320 and P67/Z68 with the 2500K
4gb or 8gb gskills
just tell me models name i need to choose, don't need to tell me price or combo, I'll do my research since I live in Canada
What i know is he dont care to put extra money so the computer last longer, because he will never update hardware, but maybe overclock but thats really notsure.
thanks a lot
Go with the Core i5 2400 as it is clocked a little higher than the Core i5 2320 and should cost the same price.
Why Nvidia?
Motherboard wise, just go with the Gigabyte GA-Z68A-D3H-B3 Intel Z68 ATX Motherboard.
RAM wise, just make sure that the RAM is rated at 1.5V and DDR3 1333 RAM speeds and you'll be fine.
PSU wise, go for the Corsair 650TX V2 650W PSU. Note the "V2" in the name. Make absolutely sure that it has that moniker in the name or otherwise you just wasted money.
Case wise, I recommend these:
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Cooler Master CM690 II Advance nVidia Edition ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
$120 - Antec Lanboy Air Yellow ATX Modular Case
$125 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$125 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$125 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$130 - Corsair Carbide Series 500R ATX Case
The 2400 is $15 more(195) from what ive seen in CAD$ and nvidia was just a starting point what would you take? Is it because nvidia is overpriced? And why z68 does he need some of these feature. Compared to a h67? I guess they are cheaper?
Thanks
Thanks
Non K quad core Sandy Bridge CPUs are partially unlocked.. meaning, the maximum multiplier for the 2400 linked above is 38, which means it can reach 3.8Ghz at stock BCLK(100), but that requires a motherboard with a chipset that allows overclocking(P67/Z68).. basically, as long as you stick to I5/I7 SandyB you want a P67/Z68 mobo for the(limited) overclock it allows :)
Regarding the PSU, the XFX Core 650 is internally the same, costs less and comes with four PCIe connectors versus the only two for the Corsair, the XFX is a far better deal.
Hmm odd. Then go with the 2130 I guess.
I would go with the HD 6950 1GB or GTX 560 TI. The TI should be cheaper than the HD 6950 1GB. If it costs more, than it's not worth it.
Couldn't think of a H67 mobo that I could recommend that was cheaper than the Z68 mobo I recommended.
