snappistol
- Mar 7, 2012
Here is a rundown list to make it easier.
Strict gaming
Whatever it takes.
Jacksonville, Florida
CPU - cannot decide on either SB/IB. (2500K or 3570K or 3750K) I will be overclocking.
Motherboard - something reliable (need advice, I dislike MSI)
RAM - 8GB reliable (need advice)
SSD - 120~GB (need advice, again something reliable; Crucial M4 comes to mind)
PSU - 650-700W I am guessing would be sufficient.
Antec 900
Video - GTX 560 ti
Hard drives - WDC WD10EADS-00L5B1 and Samsung HD204UI
6) Will you be overclocking?
Yes, using a H80
1440x900
Within 30 days.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
SATA 6Gb/s ; USB 3.0 ; will never be doing SLI
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
Comments and insight would be appreciated.
Thanks
Strict gaming
Whatever it takes.
Antec 900
Video - GTX 560 ti
Yes, using a H80
1440x900
Within 30 days.
Yes
Thanks
