Gaming Rig, Hardstyle
Linkz
Hey everyone, HardForum has been my go to for years when i want advice on new gaming rigs. Thanks Danny Bui and tiraides for the big help in past builds. Ok here we go.
Gaming, anything current and soon to come
I wanna say $800-1000 shipped, but if I have to bend a little I can.
US - Orlando, FL
CPU
Mobo
Video Card
RAM
PSU
SSD
Storage Drive
Case
Optical Drive
Mouse, keyboard, and 2 monitors
6) Will you be overclocking?
No
1920x1200, I have a 28" HANNS-G and a 24" Dell
Within the month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, SATA 6, other then that, I guess advise on what I should get
Yes, Windows 7 64 bit
Note: I want either a Orange/Black theme (those being my favorite colors) or a Razer Green theme, since I have the mech keyboard from them and I enjoy the color. Meaning like case, and mobo and ram if possible to be colored. I know I shouldn't pick a part around the color so this will mostly apply to the case. I'll be checking this frequently and replying often, so thanks in advance!
$190 - Intel Core i5-4570 CPU
$80 - MSI B85M-G43 Intel H87 mATX Motherboard
$60 - Corsair CMV8GX3M1A1600C11 8GB DDR3 1600 RAM
$260 - Gigabyte GV-N760OC-2GD GTX 760 2GB PCI-E Video Card
$99 - Samsung 840 120GB SSD
$63 - Western Digital Blue WD10EZEX 1TB 7200RPM SATA 6.0Gb/s Hard Drive
$20 - LG GH24NS95B DVD Burner
$80 - Seasonic G Series SSR-550RM 550W Modular PSU
Total: $852 shipped
As for cases, this mITX case might fit the bill:
$90 - BitFenix Atomic Orange mITX Case
Do note that if you do go with the above case, you have to swap out the motherboard in the above build list to a mITX motherboard. I recommend this mITX:
$111 - ASRock H87M-ITX LGA 1150 Intel H87 mITX Motherboard
If you want an ATX setup, these two cases fits your color theme wants:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146073
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146079
To be honest, I don't recommend either of those NZXT Phantom cases for three reasons:
1) Lack of free shipping
2) Outdated: Neither have USB 3.0 front panel ports
3) There are better cooling cases out there.
But if you must have a color theme case, then go for the NZXT Phantom Black/Green case since it currently has a 20% off promo code "NZXT20PCA13". So if theres any part I would recommend buying now, the case would be it. For shits and giggles, here's a list of cases equal to or better than the NZXT Phantom:
$100 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
$105 - Corsair Carbide Series 500R ATX Case
$144 - Silverstone RV03B-W ATX case
$144 - Silverstone RV03B-WA ATX case
$150 - Corsair Graphite Series 600TM ATX Case
Not a huge fan of the case selections but I'll thumb through more options. Do I need a Mid or Full tower case? Also why not an I7?
I have these these changes tell me if you think they are good.
RAM G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
GPU EVGA 04G-P4-3768-KR GeForce GTX 760 FTW 4GB 256-bit GDDR5
Case APEVIA X-CRUISER3 X-CRUISER3-GN Black Steel ATX Mid Tower Computer
PSU CORSAIR TX Series CMPSU-750TX 750W
I don't care weather its Newegg or Amazon, I just find newegg to be easier to navigate.
You really only need a mid-ATX case. Though you'll be fine with a good mITX or mATX case as well. Also, you're not doing anything that would require an i7 CPU.
If you can get that RAM with the $11 off promo code "0813BTS22", then that G.Skill RAM is a good choice. Without that promo code, not worth it.
As for the video card, you're not playing at a high enough resolution where that extra 4GB of RAM would actually help. We're talking about triple-monitor gaming if you want to make that 4GB of VRAM really worthwhile.
I did see that case during my search but I wasn't going to recommend it since I'm assuming you're an intelligent adult. That Apevia isn't a good choice for the money since there are significantly better quality and better cooling cases out there for around that price point. With the front door closed, that's going to obstruct a lot of the airflow coming from the front.
You have not mentioned any plans for SLI or Crossfire, heavy duty overclocking, and/or having 20+ hard drives in your system. As such, no point for you to get that Corsair 750W PSU. You'll be fine with a solid 550W PSU. Even if you needed a 750W PSU, that Corsair still wouldn't be a good choice since it's not modular and that the higher quality and modular Corsair HX750 costs like $5 more. But again, you only need a 550W PSU.
Alright just some further clarification for my part.
I'll scrap that case, I'll see what else I can find from a better company.
Now about the CPU, is going up to the 4670 a waste of money? Normally I get EVGA GPUs and Corsair PSU, any reason you choose the ones you did? Was it more bang for buck? Or they are better? I've never even heard of Seasonic before. But like I said before I consider y'all the experts.
The 4670 is a waste of money. I chose the Gigabyte GPU and Seasonic PSU because they had a good bang for the buck value. In the case of the Gigabyte, it has one of the better air coolers out there. With that said, the eVGA GTX 760 2GB with the ACX cooler would be the closest equivalent to that Gigabyte if you must have eVGA:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130933
You've been a member of this forum for 5.6 years and you've never heard of Seasonic? For shame! :) In all seriousness, Seasonic is one of the top PSU manufacturers in the world. In fact, at one point, they manufactured a lot of Corsair's PSUs like the Corsair HX620, HX520, TX650, AX850, etc. A handful of Corsair PSUs are still manufactured by Seasonic. In this case however, Corsair had nothing in the $80 price range that was of equal or better quality than that Seasonic 550W.
You can paint most cases as long as you have the skill and the right paints to do so.
Hey what about a heatsink?
Also does it matter if I have one stick of 8GB RAM vs 2 x 4GB RAM?
How about case lights? Any recommendation? I've used cold cathodes in the past and they were decent, but maybe I should go for LEDs? I'm looking for green ones.
Also I'm leaning toward this case
If you can afford it and you want an upgrade over the stock HSF:
$28 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
In terms of performance, nope.
Hit up the Cases subforum for advice on that.
The lack of a side fan kinda affects the GPU cooling of that system. With that said, not an entirely bad choice.
Update:
This is the case I will get Case
I'll probably get 6 120 fans, so should I do the Hydro or just a heatsink? Also say I wanted to get into overclocking (futureproof), how would be PSU, CPU and Mobo change?
Edit: This is my current Amazon cart
What do you think?
Not a fan of that case since it is rather cramped compared to similarity priced cases out there. The H100i is worth if you are aiming for extremely high overclocking. Otherwise, the Corsair H80i is good enough.
Ditch the AS5 as there are better thermal paste out there now like the MX5. Also if you Want to overclock, you will need to upgrade he motherboard to the ASUS Z87-A Or MSI Z87-G43.
Any other case recommendation along the same lines with more room? I like the 3.0 in the front and the glass on the side, I was gonna put orange led fans on the side of the case I had picked so maybe something else that could support that. Also the handle on top is conveint for moving for LAN parties.
Alright well thanks again, wrap up question, does it look like the H100i will fit in CM Storm Scout 2 Advanced?
What do you think?
Just double-checked that list again: Why are you getting the RAM from Amazon? It's stupidly overpriced there. Also, do not get a 2 x 4GB RAM set as that will limit your future RAM upgrade capability.
In addition, why are you getting those glasses?
It looks like you'll have to mount the H100i outside of the case as it cannot fit inside. If you're going to stick with the Storm Scout 2 Advanced, at least get a suitable HSF for it like the Corsair H80i.
Just to reiterate: I don't think the Coolermaster Storm Scout 2 Advanced is a good choice for a case since it's cramped compared to similarily priced cases out there. I don't see any good reason to get that case unless it was like $60 shipped.
I just like the style, honestly I'd much rather have the CM Storm Stryker but I'd like it in black. Now the same style in black is that CM Storm Trooper but it doesn't have the glass to show off the pretty inside. I really like the metal carrying bar for LANs and such.
I took out the glasses I was just looking at them since a friend said he got them. Also I don't think I'll ever go above 16GB RAM. But I could look at a single 8GB stick.
I just like the style, honestly I'd much rather have the CM Storm Stryker but I'd like it in black. .
Huh? The Storm Stryker does come in black. Click on the Black version of that case under "Color".
How often do you actually go to LANs though?
i.e the RAM I linked to earlier.
If you look closely when you click the black icon under "Color" it changes from the Stryker to the Trooper.
Are you a fan for the White Stryker? Its growing on me.
The RAM stick you picked out earlier looks so "plain" haha. Does the lack of a RAM heaksink matter? I suppose it would stick out less, thus giving more room.
That might be a misnaming. I'm seeing a black Stryker. Looks like the White Stryker but without the window. Oh wait, I get it now: The CM Storm Stryker is an updated white version of the black CM Storm Trooper.
Not really. The quality of the case doesn't impress me for the price it is.
No it doesn't matter. Remember that RAM voltages have gone down and therefore the need for heatsinks is even less than in the past.
I can get the White Stryker shipped for 136.00 on NewEgg. Maybe still a tad pricey but I dunno I just love how it looks. I think it's the one, and I changed the RAM back.
That promo code expires tomorrow (8/29). Are you ready to jump on that tonight?
You mean back to the Ripjaws X? Listen to Danny Bui on the RAM.
Or, we can take it one step further:
$55 - Crucial Ballistix Sport Very Low Profile 8GB DDR3 1600 CL9 1.35V DIMM
For $11 less than the Ripjaws, you have one 8GB stick of RAM with equal timings, a lower voltage, a much lower physical profile (allowing you to use any CPU cooler available), and it matches your preferred color "profile" (for lack of a better term). And again, there is no difference in performance between that solitary stick of RAM and a 2x4GB dual-channel kit.
Don't spend more money than you need to spend. Just go for the Crucial RAM.
Just wanted to put in my 2 cents worth on the case if it isn't too late. I just got a Corsair C70 Vengeance in Gunmetal Black and I love it. Very nice, well made, roomy case. It has the handles if you want to carry it to a LAN party. Also, everything is metal so it would be easy to paint to fit your color scheme. They come in Gunmetal Black, Arctic White and Military Green. If you are going to paint the whole thing, white would probably be the easiest to cover. If you just want Black with some color highlights, the Gunmetal Black looks real good. If you attend LAN parties for war themed games like CoD, Battlefield, etc... the military look would be really cool.
Looks like the white one is on sale right now for $99.99
http://www.amazon.com/Corsair-Venge...&qid=1377677742&sr=8-3&keywords=c70+vengeance
Its a neat and sturdy looking case but you can't show off your internals.
