Gaming PC
madees
Hello everyone,
I am looking for some help on building a gaming pc.
I play: SC2, WoW and in the future Diablo 3.
Gaming
Around $1,000.00
3) Where do you live?
Texas
Motherboard
CPU
RAM
Graphics Card
Power Supply
Sound Card
HDD
DVD Writer
Network Card
SD Card Reader
OS: Win7 Pro 64bit (?)
All new parts for the PC
6) Will you be overclocking?
No.
I have a Viewsonic VX2739WM (27inch)
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0; Crossfire/SLI (Looking for recommendations on these)
I plan on using Windows 7 Professional 64bit (recommendations?)
If I have left something out, please leave some recommendations.
Thanks in advance for any suggestions.
1) What features of Windows 7 Pro that you must have that makes it worth buying over Windows 7 Home Premium?
2) Do you actually have a decent sound system that makes a dedicated sound card worth buying over an onboard sound?
I would get a dedicated sound card regardless. I for one notice the hiss and crackles that on-board produces. Yes on-board is better, but still sucks and dedicated cards keep getting better. It's a catch up game.
Windows 7 Pro is not a must, it is just something I currently have.
The Speakers I have are Altec Lansing with subwoofer.
If the online sound is decent enough for gaming it will be ok.
Now I'm confused: Do or do you not have a copy of Windows 7 Pro?
I have Windows 7 Pro on my current PC and plan on keeping it.
So that is why I added Windows 7 Pro to things to buy for the new PC.
Not sure if I could just buy another key from MS or have to buy full version??
$315 - Intel Core i5 2500 + Gigabyte GA-Z68A-D3H-B3 Intel Z68 ATX Motherboard Combo
$158 - G.Skill Ripjaws F3-10666CL9D-8GBRL 2 x 4GB DDR3 1333 RAM + Thermaltake Toughpower XT TPX-775M 775W Modular Power Supply
$238 - eVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB 1GB PCI-E Video Card
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$19 - Sony AD-7260S-0B SATA DVD Burner
$100 - Windows 7 Home Premium SP1 64bit OEM
Total: $895 plus tax and shipping.
Choose your own case. I recommend any of these cases:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
You're on your own for the SD Card reader.
Thanks.
