If you can get that CPU for less than $90 to $100, then it's a good buy. Otherwise, I'd go for the $128 Core i3 2120. Even in games that scale well with multiple cores, the Core i3 2120 is gonna trump either the FX or Phenom II or at least perform just as well.
Though if you can spend the extra cash for the Core i5 2400, I'd recommend doing so.
