Gaming PC Build for around $1K
Phas3Zer0
I have been thinking about upgrading or parting out my current PC and doing a new build, but I’m not sure which yet in terms of Price vs Performance. I am mainly focusing on Extreme Gaming/music/schoolwork.
1) What will you be doing with this PC? Gaming and data storage.
2) What's your budget? $1300
3) Which country do you live in? USA, Portland OR
4) What exact parts do you need for that budget?
cpu, motherboard, memory, power supply, case, video card, SSD, HD.
5) If reusing any parts, what parts will you be reusing?
None.
6) Will you be overclocking? Yes
1920x1080, 24" Widescreen
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire
or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or
main GPU)? UEFI? etc.
Idc
10) Do you already have a legit and reusable/transferable OS key/license?
If yes, what OS? Is it 32bit or 64bit?
Yes Win 7/8 64 bit Prefer 8
Current PC -
CPU: AMD Phenom II X6 1090T 3.2Ghz -- Black Edition Processor - $216
Motherboard : ASUS M4A88TD-V EVO/USB3 - $122
RAM: Samsung Green DDR3L 1600 2x4GB - $46
Video: XFX Geforce GTX 280 1GB DDR3 - $197 (Starting to Overheat and having screen artifact issues…)
PSU: Cooler Mster GX Series 750W - $109
Hard Drive: HGST Deskstar 7K1000.C 1TB - $70
CD/ROM Drive: ASUS DRW 24B1ST - $25
OS - - Microsoft Windows 7 Ultimate 64bit
Other - SIIG all-in-one Card Reader.
New Build -
CPU: Intel Core i5-3570K $219
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASRock Z77 Extreme6 $151
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
RAM: CORSAIR Vengeance 16GB (4 x 4GB) $44.99 x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Video: ASUS GTX670-DC2-2GD5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121637
SSD: OCZ Vertex 4 VTX4-25SAT3-128G 2.5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227791
Hard Drive: Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834
Case: COOLER MASTER HAF 912 Plus (UK ONLY) Payment Total: USD 125.84
http://www.amazon.co.uk/gp/product/...iveASIN=B003XEDTLM&linkCode=as2&tag=ccreeu-21
Total is around $1200 if all purchased from Newegg. If I upgrade my current PC I plan to replace the ram/motherboard/case/video card.
What do you guys think?
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
Though, off the bat, you should budget in or get a new PSU as well as that Coolermater GX 750W is pretty much crap. Also note that the Coolermaster HAF 912 Plus isn't available in the U.S and is only available in the European and Canadian markets.
If you want to shave a few dollars off the cost, get your CPU/MoBo from Microcenter if you have a store close to you that i5-3570k = 169 or get the I7 3770k for 229 + you save $30.00 off the motherboard when you get the CPU with it. I think I have made this post enough times to make people think I work for them, but I have built 3 PCs for friends recently.
Personally I would go with a 256gb SSD. I have the 128GB and its just to dam small....
I would love to get a Samsung 830/840 or M4 in the 256gb+ range next.
