Gaming PC $800-1200
Primarly gaming, but will also web browse and watch movies.
I'm looking to spend between 800-1200$ before taxes....I have no problem getting up into the 1200$ area so long that the computer would be significantly better then a 800$ pc.
USA, Arizona, Glendale, Frys electronics near by but I would prefer to buy stuff online..
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
I don't need any peripheals or Windows factored into the cost. Just
cpu, cpu cooling, mobo, memory, gpu, psu, case? cd/dvd burner..hope i got everything there
not re-using anything
6) Will you be overclocking?
possibly down the line
7) What is the max resolution of your monitor? What size is it
1920x1080 w/ a 23 inch monitor
actually I'm hoping to purchase it by this week, maybe friday or sat
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I don't particularly care, I just want to be able to run new games very well..
Already have windows 7 oem
Here's a build:
$340 - Intel Core i5-3570K CPU + Gigabyte GA-Z77-D3H Intel Z77 Motherboard
$39 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$250 - PowerColor AX7850 2GBD5-2DH Radeon HD 7850 GHz Edition 2GB PCI-E Video Card
$110 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$22 - Samsung SH-222BB/BEBE SATA DVD Burner
$63 - Antec NEO ECO 520C 520W PSU
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
Total: $854 shipped.
Case wise, choose your own case. I recommend the following cases:
$76 - Corsair Carbide Series 300R ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
$115 - Corsair Carbide Series 500R ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$120 - Fractal Design Define R3 Silver Arrow ATX Case
$125 - Fractal Design Define R3 Black Pearl ATX Case
$120 - Lian Li PC-9F ATX Case
$120 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$130 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$130 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$140 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$144 - Silverstone RV03B-WA ATX case
$150 - Silverstone TJ04B-EW ATX Case
$160 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$164 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$162 - Corsair Obsidian Series 650D ATX Case
$220 - Silverstone FT02S-W ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
^ thanks man that looks like a solid build......heres one a friend suggested to me, opinions?
ii5-3570K $229
Asrock Z77 Pro3 $110
Mushkin 2x4GB 1600 $45
Gigabyte GTX 670-OC Windforce $400
Seagate 1TB $100 or Hitachi 1TB (more DOA reviews but longer warranty) or Hitachi 2TB $140
Crucial M4 128GB $129
Samsung DVD burner $17
PC P&C 600W $57 AR AP
Lian Li PC-K9WX $64
=$1191
Not sure about the asrock brand mobo, and prob not the coolest case i've seen, but opinions? What would you guys change?
- I don't trust AsRock as their quality has been inconsistent to say the least. I'd stick with the Gigabyte for the higher chance of reliability and better customer support.
- Which Mushkin RAM is he talking about?
- The GTX 670 is a good card. If you want to spend the extra cash, this is where you should spend it.
- The Samsung is faster than most Seagate drives. If the Hitachi drive your friend recommended is the 7K1000.D HDS721010DLE630, it is faster than the Samsung. Entirely up to you if the longer warranty + higher performance is worth the significantly higher chance of issue.
- Definitely get the SSD if you can afford it. It's gonna make a huge difference in performance.
- I don't factor in MIR. So that PC P&C is stil $76 (assuming that you can use the promo code) to me. However at that price, it's a good deal.
- That case looks cool but the case is just too cramped and its cable management isn't all that great.
-which gigabyte would you recommend?
- this mushkin http://www.newegg.com/Product/Produ...a-_-na&AID=10440897&PID=3332167&SID=u00000687
-definetly want the gtx 670.pretty set on it after reading reviews
-my friend actually said if its in my budget to get the HITACHI Deskstar 7K3000 HDS723020BLA642 over the 7K1000.D HDS721010DLE630...so i was just going to go with the 7K3000
-SSD is a must have for me :)
-What is MIR? I'm assuming you think thats a decent PC P&C ?
-any case reccomendations to accommodate the listed parts? I'd like somthing that looks pretty cool looking, ideally, and I'd even go slightly over my budget if need be.....i've seen some raidmax and nzxt ones I find aesthitically pleasing but overall I do value function over aesthitics..
hope I left good enough feedback back to you guys......let me know what you think
The one I listed in post #2
The 7K300 is an allright choice.
MIR = Mail-in-rebate. It's decent.
Apparently you didn't read my first post at all.
sorry man, for whatever reason I thought that the first post was somebody else.....I think I'm actually going to stick with your reccomendations for cases and go for the samsung over the hitchachi.....tyvm for your help
No prob.
You would be happy with any of those cases IMO. Just pick the one you like the look of the most.
