pinoydude99
- Jun 8, 2011
Gaming, usually mixed in with web browsing/schoolwork/music/some MATLAB as necessary for engineering purposes. Looking for smooth gameplay at 1920x1080, and higher graphics settings are a plus but not completely necessary.
Soft cap of ~$1300. Hard cap of $1500 with tax and shipping if really worth it. Mainly focused on getting value.
3) Where do you live?
Florida
CPU, Motherboard, Memory, GPU, SSD (if worth it), HD, DVD/etc., PSU, Case, Monitor
None.
6) Will you be overclocking?
Whatever is doable on stock HSF. Stability and consistent framerate in gaming are the main focuses.
Dual monitor setup. Currently have 25" Samsung, looking to buy a 23" ASUS. Both running at 1920x1080.
Between now and ~1.5 weeks from now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Crossfire (possible upgrade later). USB 3. SATA 6 Gb/s can't hurt.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 Pro.
Preliminary parts:
$330 - i5-2500K + GIGABYTE GA-Z68A-D3H-B3
$80 - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
$280 - MSI R6950-2PM2D2GD5 Radeon HD 6950 2GB
$120 - Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
$65 - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
$20 - Samsung SATA DVD Burner
$110 - CORSAIR Enthusiast Series TX750 V2 750W
$80 - LIAN LI Lancool PC-K58W Black
$180 - ASUS VH238H Black 23" Full HD HDMI LED Backlight LCD Monitor w/Speakers
Total = $1295 before shipping
Some thoughts on parts:
SSD: Seems like there's value enough to fit it in the budget. Is 64 GB good enough just for apps and OS?
GPU: Going with a reference HD6950 2GB. Not sure if I'll flash the BIOS, but having the option seems like a decent idea.
PSU: I figure the extra $30 or so is worth getting the 750W in case I consider upgrading with a second video card.
Thanks in advance for any and all help!
Florida
None.
Yes, Windows 7 Pro.
Preliminary parts:
