pure gaming/web browsing
about $300
3) Where do you live?
new orleans
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
RAM, MOBO, graphic card. heat sink
5) If reusing any parts, what parts will you be reusing? Please be especially specific
about the power supply. List make and model.
power supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371004
HDD
cd/dvd drive
monitor - http://www.amazon.com/Gateway-FPD2275W-Widescreen-Flat-Panel-Display/dp/B000K71SHM
keyboard/mouse
case
6) Will you be overclocking?
no
22"
in about 1 month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
not sure what these are, can someone help me out with these?
10) Do you already have a legit and reusable/transferable OS key/license?
yes.
im not sure if i should go AMD or intel, can someone tell me the difference or which one is better? thanks
about $300
new orleans
HDD
cd/dvd drive
keyboard/mouse
case
no
22"
in about 1 month
yes.
