Hi all.
If any of you can give me advice/suggestions on the following two variants that would be great.
Gaming.
£500, tax included, shipping about £10 total.
3) Where do you live?
UK
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Mobo, GPU, OD, HDD, PSU.
The case – seems a generic ATX case, should be alright cooling-wise.
6) Will you be overclocking?
Does not seem like it.
19”, 1280x1024.
As soon as the parts get decided.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
To be stable I guess.
No RAID/Xfire/SLI though.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
I have either a Phenom X4 build in mind or a i5 750, the GPU is likely to be an XFX 4870 1GB version. I am not sure about the type of RAM that the Phenom CPUs take - is not it DDR2 and DDR3? Though... does it depend on the motherboard? ... and yes - almost forgot - is this Phenom triple channel, or is it both double and triple depending on the mobo/RAM etc?
So here are the two:
AMD Phenom II X4 955 Black Edition_____Core i5 750
ASUS M4A785TD-M EVO 785G_________Gigabyte GA-P55-UD3R iP55
4GB Corsair XMS3 1600Mhz 1.65V C9____4GBCorsair XMS3 1600Mhz 1.65V C9
Samsung 1TB F3_____________________Samsung 1TB F3
XFX 4870 1GB 750M(?)________________XFX 4870 1GB 750M(?)
Corsair 650W TX_____________________Corsair 650W TX
Sony 7241s ODD_____________________Sony 7241s ODD
Total: ~ £550_________________Total: ~ £610
Both CPUs seems pretty good, however in some tests the i5 750 has a few more FPS than the 955 X4, but I could not find anything regarding GTA IV - just curious about how the two would fair.
Any suggestions would be really appreciated! Thanks a lot!
Gaming.
UK
19”, 1280x1024.
Yes.
