Gaming build
wesnerer
Gaming... FPS, WOW
$900
Virginia Beach, VA
CPU, RAM, GPU, Motherboard, Possibly a SSD.
I have a new Corsair C70 case and Seasonic X750 Gold already purchased.
6) Will you be overclocking?
Yes. I will be water cooling this system.
20" 1680x1050. Will be upgrading this in the future.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, SATA 6, SLI/Crossfire, Raid.
Yes. Windows 7 64 bit.
I will be near the Microcenter in Northern VA/Fairfax this weekend and plan on picking up a 3570k and a motherboard combo while I am there. I would also like to fit a GTX 670 or the AMD equivalent into the build.
Here's what I recommend then:
$265 - Intel Core i5 3570K CPU + Asus P8Z77-V LK Intel Z77 Intel Motherboard Microcenter combo
$46 - Corsair CMX8GX3M1A1333C9 8GB DDR3 1333 RAM
$370 - eVGA 02G-P4-2678-KR GeForce GTX 670 2GB FTW PCI-E Video Card
$128 - Samsung 840 Pro 128GB SSD
$74 - Western Digital Blue WD10EZEX 1TB 7200RPM SATA 6.0Gb/s Hard Drive
$18 - LG iHAS124-04 DVD Burner
Total: $901 shipped plux tax on the CPU and mobo.
