christianw
- Dec 16, 2008
looking for some wisdom...
Gaming
1400.00
USA
Full system build including monitor. I'd like to go with a Corsair h80 again. I had really good luck with it on my last build. Also, a 600T case.
Keyboard and Mouse. I already have a razer blackwidow and a mamba to rock with. Also I have decent speakers.
6) Will you be overclocking?
YES
7) 7) What is the max resolution of your monitor? What size is it?
N/A
In the next 12 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
stable platform for overclocking
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Going to run win8 beta until it goes live in October
Gaming
1400.00
USA
YES
N/A
In the next 12 days
