Gaming Build Opinions
aeauvian
Hey all. It's been quite a while since my last build, and I wanted to do a fresh build for gaming. I went through and made a build, but wanted any suggestions on it before I pulled the trigger.
Gaming/Programming/Web browsing
I was looking at about $1500 not including the case (which I already have). I have ShopRunner and live in Washington, so Newegg will be tax/shipping free.
Seattle, WA. Prefer to buy from Newegg.
I currently have a case, 1TB WD Black for storage, and a DVD drive. I'm looking for: CPU, mobo, ram, PSU, SSD, video card, RAM, and a CPU cooler.
Re-using my DVD drive, storage drive, and I already have a case. Re-using my monitor for now as well.
6) Will you be overclocking?
Very little. Probably just a basic overclock (4.0 GHZ if I go with a 2600k, for example).
Currently 1680x1050, but I plan on getting a Dell 2412 when they hit $300 again.
Tomorrow if all goes well.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Going for a single video card right now. I would like to have USB 3.0 available, as well as eSATA. PCI 3.0 and Sata 3 would be fun, but I'm guessing I'll be upgrading the motherboard before they become really useful. Integrated graphics are a plus. I've had terrible luck with video cards in the past, so a backup during RMA periods is nice.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 x64
I've done some research and picked out some initial components. So far:
CPU: $299.99 i7 2600k. An i5 would be plenty for gaming, but since I do miscellaneous programming/VM type stuff, i thought I could use the hyperthreading.
Video Card: $499.99 AR EVGA SuperClocked GTX 580. SLI might be an option in the future.
PSU: $159.99 AR HX 850
RAM: $35.19 AC G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600
Motherboard: $199.99 ASUS P8Z68-V PRO. This one might be a bit overkill--I was looking at a P67 but I thought the integrated graphics would be nice if I needed to diagnose any video issues.
SSD: $194.99 Crucial M4 128GB
CPU Cooler: $19.99 AC CoolerMaster Hyper 212+
So far this comes in to around 1400 after rebates, and 1450 before rebates. My budget is somewhat flexible, so if there are any suggestions they would be much appreciated.
I thought about waiting on the new nvidia cards and possibly the i7 die shrink, but I'm currently running on a 9800GT and an Opteron 165, so I think an upgrade is definitely in short order.
Thanks in advance!
Do note that the $20 off price for the 2600K is only for today I believe. So might want to buy that ASAP.
Besides being a tad pricey, that setup looks fine to me.
Thanks for the info. I can always order the processor early, so that shouldn't be an issue.
As far as the pricey note--is there anything there that would be worth saving a bit on? the most obvious contender for me seems to be the motherboard, but that would only be saving me about 50 bucks to switch to a lower end Z68 or a P67.
The -V Pro only adds 1394 and 2 extra SATA 6GB ports, so you can safely drop down to the vanilla -V if you want (although that's only a $10 savings if you stick with the Gen 3). The biggest price break would be from changing out the GTX 580 with a 6970. Saves you more than $150, and at 1080p (or 1920x1200) you aren't really going to see much performance difference. This XFX card is only $299 after rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150517
Well unless you do a ton of multi-threaded programming, I don't think HT will help out that much with your programming use. So you could save money by dropping the CPU down to the Core i5 2500K.
The GTX 580 is a good choice if you're just looking for the fastest Nvidia card available at whatever the price. But if you're aiming for a best bang for the buck value with Nvidia, I'd look at the eVGA GTX 560 Ti 448 Core instead:
$295 - eVGA 012-P3-2066-KR GeForce GTX 560 Ti 448 Cores FTW 1280MB PCI-E Video Card
Though if you're willing to go AMD, the HD 6970 2GB that Forceman recommended is a solid choice.
If you're just sticking with a single GPU, you honestly do note need a 850W PSU. You would be fine with this modular 620W PSU instead:
$90 - SeaSonic M12II 620 Bronze 620W Modular PSU
Again, if you're just sticking with a single GPU, then you would be fine with this mobo instead:
$133 - Asus P8Z68-V LE Intel Z68 ATX Motherboard
Ah, thanks for the info on the V vs. the V Pro.
I looked a bit into the 6970. It's tempting, but I'm not sure about ATI. I've heard of issues with drivers, and if I decide to add another card in the future it seems like ATI is slow to update for crossfire.
Alright, I might switch over to the 2500k then.
How is the performance between the 560 ti and the 570? Looking at the prices, it was thinking going with a single 570 and then moving to SLI later would be better bang for the buck than the 580.
